Showing results for tags 'push stick'.
Another stupid, unsafe, advertisement photo
kmealy posted a topic in Machinery, Tools, Research, Reviews and Safety
Kickback waiting to happen. This one is not even from a Chinese company, it's a Canadian one (Though I don't know where it's manufactured).. A battery powered table saw.- 18 replies
- push stick
- kickback
(and 2 more)
Reading the push pencil/sticks/ice picks, knew I needed to throw this in. Old hand saw handle or cut exact copy to start. Cut 1/2'' ply bout 10'' high to attach that handle, 12" 18'' long shaped like that old hand saw. attach the 12'' or 18'' into the handle. Under the handle on the ply bottom. Cut the ply leaving a heel under the handle bout 1/4 ?high? to engage/catch the piece being pushed. Out at end of the 12'' 18'' ply,or more, glue some 80 grit to hold on to piece being pushed. Handle attached to 10'' high part is for safety. Now your hand is well above the blade & you have control.
- 1 reply
- push stick
- table saw
(and 1 more)
These are my push sticks (no I have not been pushing @Stick486 around). The First is a 2x4 with notch cut out and corners rounded over and is used on the router table. The second is a simple piece of ply with notch for pushing and I use it on the bandsaw. The third is my standard cut from ply and allows gluing a replacement push block to the rear. The monster allows me to keep my hand as far as possible from the blade as possible, but it is cumbersome to use.
