Showing results for tags 'natural edge bowl'.
Unbelievable, planted tomatoes last week supposed to be in the low 30's tonight! I hate this global warming! Our Patriot Turners- @Ron Altier brought us up-to-date on his epoxy finish for ornaments. Looks like he has pretty much perfected the process. Ron provides lots of tips on how he gets this mirror like finish- Several members posted in our "What's On Your Lathe" this past week. You can catchup with the new posts here- @forty_caliber added a couple and @teesquare added this beauty (and a couple of other pieces as well)- Do yourself a favor and check out all the new turning in the past week! What’s Coming Up- Click on the images for links to more information and registration For The Newbies- Thinking about turning that first bowl or maybe just need some more pointers? Kent Weakley's video could be what you are looking for. I thought this one was particularly helpful with the dialog and tips throughout the presentation. Richard Raffan puts his spin in the natural edge bowl project- Something to think about from Ron Brown's newsletter- This Is Just The Beginning It is easy to forget how much you have learned along the way. New turners also have to learn the same things we did. Or, if you are a new turner, there is much to learn. You can learn to sail in an hour – It takes a lifetime to become a sailor It is the same with learning about a wood lathe. Just like any other craft, getting the machine is only the beginning. Let’s start with the Four Pillars of Woodturning: #1-The Wood Lathe Itself There is a multitude of quality wood lathes available to fit most budgets. The most common starter lathe nowadays is a 12 to 12.5-inch swing lathe with a 1 hp variable speed motor. Many folks will keep this lathe when they upsize to a larger lathe with swings of 16 to 25” and motors up to 3 hp. #2-The turning chisels Beginning turners will see much faster results if they begin with carbide-tipped tools. A sharpening station is not required for carbide tools. High-Speed Steel tools require frequent re-sharpening and require a suitable sharpening station (more in #4) The turner must learn a whole new skill set for sharpening in addition to learning woodturning. #3-The means of holding your work Most lathes come with a spur drive center for the headstock and a live center for the tailstock. Great for beginning spindle projects like baseball bats, lamps, etc. Most lathes also come with a faceplate mainly used for turning bowls. I consider a 4-jaw scroll chuck a basic necessity. I recommend extra jaws also Pin jaws for very small spindle projects #3 or 100 mm jaws for larger spindle work and for many larger bowls. #4-A sharpening station Slow-speed grinders (1750 rpm or similar) with 8” grinding wheels made to work with High-Speed Steel are recommended A sharpening jig specially designed for sharpening lathe tools is virtually a necessity when using HSS lathe tools. Note: Using only carbide-tipped wood lathe tools eliminates the need for any kind of sharpening station and eliminates 25% of the learning curve and initial expense. Folks trying their hand at any new craft are much more likely to stick with it if they can experience early success. Easy projects to learn on are pens, small bowls, spinning tops, and small lidded boxes. Someone can successfully make all of them with simple carbide tools. Some folks only turn bowls while others only turn pens. As long at they turn something, I’m happy for them. Most folks who begin using carbide tools eventually add HSS tools and a sharpening station down the road. I recommend that route to see if they are going to enjoy turning wood and if they are going to stick with it long term. It seems like you never have every widget you want, but over time you can accumulate most of them. Remember that you can turn small items on a big lathe, but it is much harder to turn something big on a small lathe. So get ready to see that huge smile on that kid’s face from ages 8 to 88 when you show them how to make their first slimline pen or maple bowl. There is nothing like it! Expand Your Horizons- In last week's post, one of the "What's Coming Up" events were classes on turning kitchen utensils. The classes were at Highland Woodworking in Atlanta, GA. Not everyone can travel that far to learn to turn a spoon, so I found a bunch of videos, if you'd like to give it a try. If kitchen ware isn't your thing, Mike Peace demonstrates how to add an insert to a turned box New Turning Items- Sorry, couldn't find anything this week Everything Else- Started working on one of the elm rough blanks. I have enough meat on the bottom to remove some of the thickness around the mortice. It will make the thing set a little lower on a surface and lighten up the piece a bit. Safe turning
- 4 replies
- ernie conover
- ron brown
- (and 21 more)
Starting into another month already. This is April and taxes are due in a little over a week. Hope our turners post their new tools purchased with those gigantic refunds! Our Patriot Turners- @Reese Aukee showed us some more of those cute little hedgehogs she turns. Reese received lots of positive comments and some questions about her turnings. Check out her post- @Gerald posted a comment in our sub-forum for Ring Master Turning. We have an ongoing thread in our woodturners forum discussing how we decide what to make from a chunk of wood. @Gerald suggested this topic and we have had several entries. Please take some time to see the thought processes (or lack thereof ) when trying to decide what to make. We look forward to seeing your turnings and how they came to be. If you are into turning miniatures, @kmealy showed us a neat portable lathe. He received lots of comments! ¹ What’s Coming Up- Click on the images for links to registration and more information- Cindy Drozda has been offering both paid and free online presentations. If you would like to receive notifications of her events, check out this link- http://www.cindydrozda.com/html/Signup.html For The Newbies- A hodgepodge of videos to help us be more knowledgeable as beginning turners- Have some wood from a downed tree? Ashley Harwood has a few tips on helping prevent logs from cracking- Of course you need to first get that tree cut into manageable chunks. Here Lyle Jamieson and Sam Angelo have some tips on using the chainsaw- In combination with a chainsaw, the bandsaw can be used to create turning blanks. Robo Hippy's informative video gives us lots of pointers- Expand Your Horizons- Once you get that tree log into a manageable blank, you can create a beautiful natural edge bowl. Lyle Jamieson shows us how. If a natural edge bowl doesn't thrill you, here, Kent Weakley shows us how to turn a "magnetic" paper clip bowl! With Easter coming up fast, a cool turning from Alan Stratton on turning the perfect egg- What is a Kuksa? And How to Turn One? Mike Peace does some turning, carving and shaping! Basket weave illusion bowls are quite popular. Carl Jacobson turned something a little more shapely using the basket weave process. New Turning Items- For the pen turners, Craft Supplies USA has a new pen kit- Hobble Creek Craftsman King's Camo Bolt Action Pen Blank Click on the image for the link to more information Everything Else- Rick Turns list of YouTube woodturning videos from last week- Safe turning ¹ Only available on April 1st.
- 4 replies
- wednesday
- wisdom
(and 33 more)
- wednesday
- wisdom
- woodturners
- hedghog
- pine cone
- ring master tool
- what to turn
- miniature lathe
- woodturning boxes
- scott hampton
- aaw
- oval box
- todd raines
- cindy drozda
- log preservation
- chainsaw
- ashley harwood
- lyle jameson
- sam angelo
- robo hippy
- bandsaw
- bowl blanks
- natural edge bowl
- kent weakley
- magnetic bowl
- alan stratton
- perfect egg
- kuksa
- mike peace
- basket weave
- carl jacobson
- pen kit
- craft supplies
- videos
- rick turns
