Showing results for tags 'gun case'.
After milling and sizing the sides and ends, it was time to layout the dovetails. I use a shop made angle layout jig for the tails. I'm a tails first dovetail person. I know there are folks who do the pins first and there are valid arguments to each procedure. This is how I learned to do them and it works for me. I use a marking knife for laying out the dovetails and a marking gauge to locate the dept of cuts. As for cutting the the dovetails, I really like the Japanese pull saw. I only have the Dozuki (cross cut) but it works OK for all of the cuts. Maybe one of these days I'll get a Ryoba and do things the correct way. Layout of the location of the dovetails was straight forward- I didn't take a bunch of pix during this part- One of the design problems was that I wanted to keep the tails fairly consistent in width. However, the box will be split after the assembly so the saw kerf will change the dimension of the tail width. To compensate, I needed to make one of the tails slightly wider. I made a full size template in Sketchup to help me figure it all out. A white artist pencil for labeling all of the pieces to maintain the proper orientation. A mock-up of one of the corners helped me see how things were going to go together. Including the cut that would eventually separate the top and bottom You would think, at this point, I would see the giant mistake staring me in the face- but Nooooo! Next part, the near fatal error and how I fixed it
The sides and ends needed to have dados to accept the top and bottom. So as not to have the dados extend through the pins, stopped dados would do the trick. These were made on the router table. 1/4" wide and 5/16" deep. It was time for a little finessing of the joints to assure everything fit. Yes, there it was staring me right in the face! How could I not see what I did. Worse yet, how am I going to fix it now?!?!?!? I picked up the test piece and it finally hit me! If I cut the top completely free, there will only be one pin for the lid "tail". There will be no structural element (second pin) to hold them together. Even the best glue won't hack it here. Hmmm... can't weld wood together. Maybe a glue block on the inside corners. There's not much material between the top and the edge of the lid. At this point I stopped and went for a long walk. Several thoughts went through my mind- including selling all my tools and just sitting on the porch watching cars go by. But then it came to me- After assembling the box, I could drill a hole in each corner. The depth of the hole would be just shy of the saw kerf. Gluing a dowel into the hole should provide enough strength to make the joint stable. Next time- making the top and bottom.
Having solved the problem of the non-supported dovetails in the lid, I made a dry fit of the sides and ends Most often, I like to make actual measurements rather than rely on what I calculated the size of the pieces I'll need. The good old Stanley Folder is my go-to tool for this type of measurement. Once the dimensions are taken, I can size and create the top and bottom. Both pieces were made from glue-ups. The top is 1/2" stock. The bottom is created from some thinner stock glued up to make the panel.; then planed to 1/2" thick. The bottom and top set in dados. The bottom is rabbeted to make a 1/4" tongue for the dado. The top is a raised panel made on the table saw. To make the top, the first thing is to create a crisp edge for the raised portion. The cuts are about 1/16" deep and will form the lip of the raised portion. The distance from the edge of the panel to the cut is sort of a trial and error method. Layout on a test piece, cut, check. I make my raised panels with a 7° angle. It seems to work best for me. To make the angled cuts, I use a shop made raised pane jig. It is sort of an overgrown tenoning jig. The down side of this method is that it requires a fair amount of sanding on the bevel to get rid of the saw marks. The up side- I don't need to buy a giant router and a set of raised panel bits. Don't get me wrong- I'm not opposed to buying more tools. However, a bigger router means I'd have to rebuild my shop made router table lift. Now it is just a matter of dry fitting the entire unit together- Next time, the glue-up, fix for the dove tail mistake and splitting the box.
Once everything was properly fitted, the case was disassembled and prepped for gluing. I had previously sanded all of the pieces to 150 grit- except the top and bottom. Those two were sanded to 220 grit due to the difficulty of sanding them in place. I taped the locations where the dovetails intersected- on the inside of the box- to help eliminate a lot of glue squeeze out cleanup. Assembled one end and two sides. Dropped in the top and bottom. Then glued in the last end piece. Some clamps, checked for square then set it aside for a day- Next up, was fixing the dovetail error. I went back and forth between matching or contrasting dowel pins. Finally settled on walnut. My first idea was to create dowels, that when installed, had the flat grain exposed. This would make them almost invisible. However, my goal was also to increase the strength of the joint. With the grain running across the dowel diameter, the dowel could be easily snapped in half. Back to the lathe- Grain running lengthwise. Drilling the corner holes was done on the drill press. My drill press table sets slightly off center. This presented a little bit of an problem when drilling two of the holes. The case extended quite a bit off of the side of the drill table and needed to have additional support. I used to have a shop made adjustable support just for this purpose- but I never used it. NOTE TO SELF- Don't throw anything away! Dowels were then glued into place and trimmed with a flush trim saw. Sanding all of the dovetails flush and the case was ready to be split. Using the table saw and a really thin blade- actually the blade off of my miter saw- I made a cut around the outside of the box. The saw cut did not completely separate the top and bottom. I left a little bit of material to hold the two pieces together throughout the cut. To complete the separation, carefully cut through the material with a sharp utility knife- The completed cut- Finally, sand the excess material left in the cut (I don't trust myself with the hand plane). The blue tape on the inside corners needs to be removed. That really facilitates cleaning any glue squeeze out. When the hardware and liner gets here, we'll continue. I'm not sure what my friend has picked for hinges/latches or what kind of finish- just hope he doesn't want latex paint!
The final installment of this project is just a little follow-up on the last details. My friend supplied the hardware and liner for me to install. The latches snap securely and installed easily, as did the hinges. The only caveat was that the sides of the case were 1/2" thick and the screws were a little longer. The difference isn't noticeable due to the type of liner he chose. The short protruding nibs actually help keep the foam in place. I had never worked with this material. There are a few videos on the Internet explaining how to cut and shape it to your needs. Because I was placing it inside a box and the fit needed to be perfect, I cut the foam to size on my table saw using a fine toothed blade from my circular saw. Worked Perfectly!! I was able to get both the lid and bottom liner from a single sheet of 58mm material. The box bottom used the piece's full thickness. The lid, however, needed the material to be a little less than 1" thick. The plan was to simply separate the 58mm foam into a thinner sheet. The foam is manufactured in layers. The concept is to cut out an outline of the item you want to store and then remove the foam layers to create a cavity. My thoughts were- "Hey, I'll use the same idea and just thin down the thick piece." Not so fast, pilgrim! Let's just say it sounded easier than it turned out. The surface where the material separated is extremely rough. Fortunately, that surface is not seen. He still hasn't decided on a carrying handle. He is thinking of something like a woven becket- My friend comes from a family of "finishers", so I think that part of the project will be handled by them. Well, that's it! Thanks for reading along
I was driving home Tuesday when I realized that I wanted a retro gun case for my recently acquired 1874 Sharps rifle. I stopped in to HD and picked up the supplies I needed for the project. Since I do not know how to make those fancy interlocking corners in the wood I had to rely on butting the ends of the wood and gluing them. The joints are a skill I need to learn so I am asking for help with this . Anyway I applied my homemade alkanet root stain and the waxed. I think it came out pretty good. I still need to put the dividers inside and install the green felt but I think this case should work well.
OK folks, time to put on your thinking caps. Like most of y'all, I have several hobbies outside of woodworking. I love to build and fly kites but I'm also a "gun guy" so one of my next projects is going to be building an American flag gun case. The idea behind the case is to build a piece of eye candy that will hang on the wall built it will double as a secure hide-a-way for a few guns that can be quickly accessed. Here's my dilemma. I want the case to be secure from inquisitive children but also have quick access to the weapons so I need a system to secure the guns but also be able to quickly access them. I thought about a bio metric lock but I can't find one that it reasonably priced. John Moody and I also discussed maybe putting a pair of recessed finger latches at the top about 3 feet apart at the top. So, any ideas? There are several different styles but courtesy of the ProtectYOURshelves store on Etsy, here's a picture of one that is available. https://www.etsy.com/listing/468196428/red-white-blue-concealment-flag?ref=shop_home_feat_3
Briefcase to transport pistols
Gene Howe posted a gallery image in Small Crafts, Boxes, Picture Frames, and Lighting
From the album: Gene's Stuff
Mesquite and maple. Purchased Hardware.
