May 28May 28 comment_376811 Just a heads up about one of our turners, @Gerald. He spent some time in the hospital and needs to wear a heart monitor. Prayers will be greatly appreciated.Our Patriot Turners-@John Morris gave a nod to a beautiful turning from Kerry Woodturning-Couldn't find a website for him but if you do Facebook, here's a link to his page-https://www.facebook.com/profile.php?id=61581895137706@RustyFN was not deterred on his quest for a bowl from a board! As spoken by Chief Dan George as Lone Watie, in the movie The Outlaw Josey Wales, "Endeavor to Persevere." And he did-Check out the additional images and Rusty's continuing adventures-Rusty also tested our collective brain power for help with a question.He received a couple of comments. Check his post and see if you can help.What's Coming Up-Cindy Drozda posted the replay of last Friday's Tool TalkThis Friday, May 29, 2pm EDT will be Tod Raines presentation ofRegistration- https://streamyard.com/watch/QTjdcuZbYCNq?omnisendContactID=6965451f10a273e815a3a1d1Registration- https://www.aawsymposium.org/registerMore information at- https://popular-woodworking.mykajabi.com/offers/oy2VUxij/checkout?coupon_code=PW35For The Newbies-Mike Peace has some good tips and safety information about using drive spur centers-A little bit of turning but a whole lot of cool for displaying your smaller turnings!Want to add some interest to your turning, Wire burning can do that. Tim Yoder demonstrates-https://www.facebook.com/reel/3762345817236202Expand Your Horizons-Tommy Tomislav demonstrates how he turns his Ball Puzzles-Richard Raffan turns a perfectly round bowl, adds 3 feet and then dries it in the microwave. So much for being round!Turning Time With Easy Wood Tools-Easy Wood Tools products in action!https://www.instagram.com/p/DYuSadmxiO3/Upcoming Easy Wood Tools demonstrations-https://www.aawsymposium.org/registerhttps://www.woodcraft.com/pages/store/daytonNew Turning Items-From Robert Sorby, a new design on a Wobble Chuck-https://www.packardwoodworks.com/118730.htmlFrom Niles Bottle stopper, Whiskey Smoker Screens!https://nilesbottlestoppers.com/product/whiskey-smoker-screens/Everything Else-Been working on idea for another glued up turning blank. Finally have the cutting jig made and learning how to use it.Instead of starting from scratch with a jig, the base of the John Beaver/Alan Stratton hybrid jig is used as an adjustable pivot point. The circular arc part is mounted to it.Modified toilet flange bolts are used to capture the T-tracks allowing the arc portion to swivel and pinned at the desired distance from the bandsaw blade.A 1/4x20 bolt/nut was modified to act act as a pivot point for the actual turning blank. This pivot point sets arc distance from the blank edge to the center.The T-track also provided a way to lock the turning blank into place when making the arc cutThe end result, hopefully will be a shallow bowl and/or platter similar to thisThe arcs will need to cut free and a thin slice of contrasting wood glued into place. Each 2 piece segment will be glued back together and then turned. (He says with foolish authority)Safe turning Report
May 28May 28 comment_376819 Thanks for the mention Lew. It is amazing what 2 days in hospital bed can do for your stamina. Got to see what mike has to say about drive centers. Report
May 28May 28 comment_376827 That's a pretty cool arc jig, Lew. Are those cuts smooth enough for gluing or do you sand them down a little? Report
May 31May 31 Author comment_376979 @HandyDan Thanks!@Gerald Thank You!@Fred W. Hargis Jr Thanks! The arcs are pretty smooth. I'm testing now to see if it will work without sanding. Making a clamping jig for glue ups.@RustyFN Thank You!@Rusty S Thanks! Report
