June 12, 20242 yr comment_337145 Beautiful day in south central Pennsylvania... Our Patriot Turners- @Fred W. Hargis Jr Started a new turning and a new challenge for him- Fred had several questions about the best way to mount the piece on the lathe and some procedural turning questions. Our gang wasn't shy about offering their ideas and included some images of what they have done. Check out all of the interactions here- There were a couple of new comments on Fred's post about the lidded box he had turned. You can see the comments and images at- @kreisdorph scored some freshly cut oak. He turned this lovely bowl as a gift for the person who gave him the wood. Always a great thing to repay a gift and this lets the tree live on. What’s Coming Up- Click on the image for the link to registration and more information- For The Newbies- Sometime turners will uses different terms to describe the same thing or vice-versa. Here's Mike Peace's take on the Natural Edge Bowl and the Live Edge Bowl- And here he shows us his techniques for turning a live edge, or is a natural edge, bowl??? And from Lyle Jamieson, a tip on creating a strong glue block connection for bowl turning. Expand Your Horizons- Richard Raffan shows his method of sanding the inside of his turned boxes. Nice tip! Tired of turning bowls? Looking for another form that will be well received as a gift? Try turning a platter- New Turning Items- New style bronze threaded rings from Niles Bottle Stoppers Everything Else- Ron Brown's newsletter included a free sharing of his published list of woodturning "Pearls of Wisdom" and a free download of the Turners Reference Guide. Ron Brown’s Pearls: Turners Reference Guide© brought to you by Ron Brown’s Best, LLC 1. There are exceptions to every rule except this one. 2. Six types of chisels are needed to make up a basic turning set (Spindle Gouges, Roughing Gouges, Bowl Gouges, Skews, Scrapers & Parting Tools). 3. Sharp Lathe Tools are more fun. 4. Speed formula: diameter in inches X speed in RPM should equal 6,000 to 9,000 (10” X 800 RPM= 8,000). 5. Rub the bevel on all cutting tools; not on scraping tools. ABC= Anchor the tool, Rub the Bevel, Pick up the Cut. 6. Have safety gear on hand and use it; full face shield, dust mask. 7. Always rotate the workpiece by hand before turning the lathe on to check for interference. 8. Start at slow RPM to check for balance, and then speed up. 9. Speed can be our friend. 10. If you are afraid, slow down and take a breath. 11. “Life’s too short to turn ugly wood.” John Jordan. 12. Carpe Lignum, Torne Lignum – Seize the wood. Turn the wood. 13. Variable-speed lathes are better. 14. Learn to hone. 15. Have a plan before you start. 16. Be Flexible. 17. Turn green wood often. 18. Greenwood is like lettuce, cut what you can use or it will spoil. 19. Learn to use your tools well and keep them sharp. 20. Sharp tools are safer. 21. Sharp tools produce better results. 22. Invest in a good sharpening system and learn to use it well. 23. Then teach others. 24. Don’t skip grits. Never jump more than 50%, i.e. 100 grit to 150 grit to 220 grit to 320 grit. 25. Your family will love whatever you make. 26. Listen to your spouse; they usually have a better eye for design. 27. Never point out your mistakes to others. 28. Spindle turning often requires more skill and imagination than bowl turning. 29. “Never scrape when you can cut.” Mike Mahoney. 30. If you must scrape, raise a fresh burr. 31. Get and learn to use a ¼” wide parting tool. 32. Learn to make lots of “Fun Stuff” like tops, pens, stoppers, light pulls and small lidded boxes. It will make you a better turner and your family will think you are a genius, especially at Christmas time. 33. Make Christmas gifts for your family every year and start in June. 34. Invest in education like classes, seminars and symposiums. 35. Spend the money for personal one-on-one instruction with a professional turner. 36. If you are not failing every now and then, you are not learning. 37. You learn the most when you teach others. 38. Buy good quality M2 High-Speed Steel tools. Avoid high-carbon tools; they are a waste of time. 39. Learn to turn right and left-handed. 40. You can use a bowl gouge on spindle work, but usually not the other way around. 41. Sandpaper is cheap; throw it away often and use fresh stuff. 42. Sign and date your workpieces along with the kind of wood. 43. Buy the best chuck you can afford, and then buy lots of jaws for it. Then buy another chuck. 44. Make your own tool handles. 45. Try someone else’s tools. They might know something you don’t. 46. Join an AAW chapter then go to the meetings. 47. Read turning magazines. 48. Watch turning videos on YouTube, but don’t believe everything they tell you. 49. Buy educational DVD’s. https://longworthchuck.com/index.php?route=product/product&path=10&product_id=219 Turners_Reference_Guide.pdf Safe turning Report
June 12, 20242 yr Popular Post comment_337146 Sure is nice to see someone like @Fred W. Hargis Jr get the turning itch. I hope he comes to enjoy it as much as I do. Thanks for this weeks post. Still not getting much shop time. Get to feeling better and something else happens. Legs swelled and feet didn't want to go in the shoes this week. Another pill seems to have solved that after a couple trips to the blood letter/doctor. Fun stuff. Report
June 25, 20242 yr comment_337848 On 6/12/2024 at 5:20 PM, HandyDan said: Still not getting much shop time. Get to feeling better and something else happens. Legs swelled and feet didn't want to go in the shoes this week. Another pill seems to have solved that after a couple trips to the blood letter/doctor. Fun stuff. Just now saw this. Hope you're doing better Dan? Report
