June 16, 20233 yr Popular Post comment_316169 The same friend that gave me the nesting table to repair gave me a chair to take to the furniture bank. It needed some help. It had been "sitting in the attic for a while." Seat was a mess and bird poop over many spots. As an aside, I think this is the first piece I've ever worked on that had a wipe-on stain and not just a spray on toner, given the marks on the bottom of the seat base. Procedure: Take off set cushion Clean with naptha, then soap & water The finish had deteriorated around where the hands would be on the arm. This happens with exposure to body oils over time. I tried to clean up, but no luck, so It got sanded off. The upper back was salvageable with a cleaning and light sanding. Apply a coat of shellac to seal over most of the areas. Apply aerosol toner (lacquer with color in it) in dark and extra dark cherry Apply clear lacquer as a top coat Flip the top of the padding over and add several layers of polyfill padding Reupholster the top with new fabric Reattach the seat Before: Atter seat removal and sanding arms New upholstery on seat Finish repairs All done Edited June 16, 20233 yr by kmealy Report
June 16, 20233 yr comment_316178 I have been enjoying following along. You can take what others may of thrown away and make something out of it. thank you. Danl Report
August 28, 20233 yr comment_320211 The color of all done seems to be much darker than finish done I guess this is some sort of lighting issue? Report
August 29, 20233 yr Author comment_320225 8 hours ago, Michael Thuman said: The color of all done seems to be much darker than finish done I guess this is some sort of lighting issue? Yes, lighting/flash, I didn't do anything to the legs or middle of the back and you can see how much darker it is Report
June 21, 20251 yr comment_357850 Could you tell me who made the chair.i have an arm chair and 5 dining chairs just like it Report
June 22, 20251 yr comment_357873 19 hours ago, Chuckles said: Could you tell me who made the chair.i have an arm chair and 5 dining chairs just like it Hey welcome to our community Chuck! I understand the curiosity to know what company made the set, is there a specific reason why you'd like to know? If you are trying to fix something there is probably a way around knowing who the manufacturer is. Report
June 26, 20251 yr Author comment_358075 On 6/21/2025 at 5:58 PM, Chuckles said: Could you tell me who made the chair.i have an arm chair and 5 dining chairs just like it Sorry, it's long gone Report
June 26, 20251 yr Author Popular Post comment_358077 On 6/22/2025 at 1:31 PM, John Morris said: @kmealy where's Quick Fix Up #1 ? Here, took about 45 minutes with a lacquer toner and clear top coat Before: after: Report
June 26, 20251 yr comment_358079 10 minutes ago, kmealy said: Here, took about 45 minutes with a lacquer toner and clear top coat Tanks Keith, I was wondering if you have a topic posted for the #1 or titled differently but related? I was gonna group em for ya for easy access. Report
