August 28, 20224 yr Popular Post comment_297579 Since my working with power tools has had to be considerably reduced because of health issues, I have gotten in the shop for some smaller projects. One is a model build of a Chris Craft speed boat and another is a scroll saw cutting and assembly of a tissue box cover. The Chris Craft did consume a bit of time. The whole hull assembly was done in two layers, the first layer using balsa wood strips' and a second layer using mahogany strips. The tissue box was cut using 1/4" birch plywood. This was my first attempt at using the Delta scroll saw for anything more than practice. Report
August 28, 20224 yr comment_297585 Wow! Nicely done! On a side note, there just isn't any thing quite as beautiful as those Chris Craft boats, your model really is nice! Report
August 28, 20224 yr comment_297587 Small is beautiful, as you have so deftly proven. Very nice work. Al. Report
August 28, 20224 yr comment_297589 Most excellent work Al. Great detail on the tissue box cover. The Chris Craft model is...well...GORGEOUS! Just looking at it, I can hear is burbling in the water waiting for the skier to give thumbs up. Amazing. Report
August 29, 20224 yr comment_297598 Most excellent job on both. I do not see any restrictions in your work in viewing these. Report
August 29, 20224 yr comment_297599 The boat is magnificent! And the tissue box seems to indicate some pretty good chops with the scroll saw. Report
August 29, 20224 yr Author comment_297609 Thanks everyone for the responses. I enjoyed these projects. Had some problems with the aluminum foil and did mess up the windshields with glue on the boat but otherwise I thought it came out OK. That old Delta scroll saw works great. Looking forward to more projects. Report
August 29, 20224 yr Popular Post comment_297613 Was watching NCIS, your boat looks like the one Gibbs built Report
August 29, 20224 yr comment_297629 Those both turned out super Al! What Delta saw are you using? I thought you did a nice upgrade a year or so back Report
August 29, 20224 yr comment_297643 Good projects Al. Nice fit on those Mahogany strips on the boat. Smooth and even. Report
August 30, 20224 yr Author comment_297712 On 8/29/2022 at 7:21 AM, Cal said: Those both turned out super Al! What Delta saw are you using? I thought you did a nice upgrade a year or so back Thanks @Cal. The scroll saw I had was the Wen 16" Model 3923 I believe. It was supposed to be able to use pinned and pinless blades but changing pinless blades was really a challenge. I now have the Delta model 40-640 20". It's an older scroll saw but pinless blade changing is simple. Much heavier and more stable while cutting than the Wen and the variable speed is a great feature. An oldie but a goodie. the saw is much heavier and more stable while cutting. Report
August 30, 20224 yr Popular Post comment_297717 Beautiful work indeed! I may actually have a scroll saw but since buying it I got frustrated by the pinless blades it used. Your tissue box project is a great excuse for digging mine out to see if time and experience can make some use of it. Maybe to see if I can update it to use pinned blades. I've got a little name plate with my name cut out using that saw and it is the only project I remember scroll sawing. Since getting a small CNC that can use bits as small as 1/32" tiny details I've done using it. 4D Report
August 30, 20224 yr comment_297725 Hey everybody done said what I was thinking. Those two scroll saws are about as far apart as they can get to make a good scroller out of someone. Just don't even think of stopping woodworking. I could ever send you some patterns if you can't find some to keep you busy. Report
August 31, 20224 yr Author Popular Post comment_297728 Thank you @Smallpatch. Definitely agree with your comment about the difference between the two scroll saws. At this point in my life, scroll sawing really is a chance to continue working with wood. Report
August 31, 20224 yr comment_297730 3 hours ago, Smallpatch said: Just don't even think of stopping woodworking. @Al B...what Patch said!!^^^^^^^^^ Report
