Posted
Great buy , I am sure she will do well with it. Maybe even turn a table or stool leg or two.
Posted
She can turn to her hearts content now.  I have a spare head stock if you would need it.  I removed the shaft and bearings and used them in another project.  My lathe is the Yellow version.  Same lathe same model number just a few changes.
The motor on mine had the internal wiring to run it either direction so I wired in a double pole double throw switch to it to make give it reverse capabilities.  I also upgraded the tool rest holder.  Bought one on E-Bay from a Delta midi lathe so it now has lever lock.
Posted
Thank you and I will keep this in mind. Appreciate the pictures for comparison.  I see the tail stock on yours has what appears to be lever lock as well.  I may keep my eyes open as that would be a “nice to have” option for her, especially for the tool rest.  My budget for this project is about taxed out for the moment but I will upgrade her with the right opportunity.  Appreciate it.
  Only 75 emoji are allowed.
