Popular Post Gunny Posted December 12, 2018 Popular Post Report Posted December 12, 2018 While I use the same tape / rule / square for a given project I still do other work outside the shop requiring different tape measures. Do I really need a 25 ft tape to measure most shop projects inside a 16x20 shop, hmmm no. But work outside doing forms for concrete, building sheds I do need one. Then of course we come to specialty tapes such as a center finder tape or a metric tape. Yes I know about the ongoing debate of Imperial verses metric. Not even going in that direction. Previously I had them laid out in a drawer and that worked well until I got a new 25 ft one and it just was too big to fit. Jammed the drawer more than once and said enough. While I was at it I also could use a place to put my glasses. On top of the oscillating sander was not a good place. Added some pencil storage because I always seem to be needing one and you can never have them close enough to what you are working on at the time. Small project, still takes several days to do finish work and let cure well before installation. It is all about the details. Used some rubber backed flooring turned rubber side up to protect the wood from the viscous tape measure ends. Also keeps them all canted at a slight angle. In theory this keeps them from falling down. Once done a great addition that will prove useful for years to come. We like pictures so I took a few as the installation went along. p_toad, HARO50, Stick486 and 8 others 11 Quote
Grandpadave52 Posted December 12, 2018 Report Posted December 12, 2018 4 minutes ago, Woodbutcherbynight said: Used some rubber backed flooring turned rubber side up to protect the wood Good idea...all of it looks great. Thanks for sharing. Gunny 1 Quote
Popular Post Grandpadave52 Posted December 12, 2018 Popular Post Report Posted December 12, 2018 6 minutes ago, Woodbutcherbynight said: Added some pencil storage because I always seem to be needing one So that's where all my pencils rolled to? Artie, Stick486, Dadio and 4 others 7 Quote
lew Posted December 12, 2018 Report Posted December 12, 2018 That'd be great, if I could remember to always put them back! LarryS, steven newman, HARO50 and 3 others 2 4 Quote
Popular Post DAB Posted December 12, 2018 Popular Post Report Posted December 12, 2018 whoa, you guys use tape measures? my thumb is 1" wide exactly. my hand is 4" wide, my span is 9", and my cubit is 18". i'm good to go. right?? a royal cubit was one cubit (elbow to tip of fingers) plus one hand (width of hand, not including thumb), about 22" for me. LarryS, Stick486, DuckSoup and 4 others 2 5 Quote
Popular Post Gene Howe Posted December 12, 2018 Popular Post Report Posted December 12, 2018 If I were a Carpenter, I'd sing the praises of a tape measure. I'm not a Carpenter and, I can't sing. Nor do I use a tape measure. Dadio, Stick486, Cal and 2 others 1 4 Quote
Popular Post Grandpadave52 Posted December 12, 2018 Popular Post Report Posted December 12, 2018 48 minutes ago, DAB said: whoa, you guys use tape measures? 19 minutes ago, Gene Howe said: Nor do I use a tape measure. Uhhhh...well then how do you guys measure a project after it's done to see if it will fit through the shop door? Stick486, Gerald, Gunny and 7 others 1 9 Quote
Popular Post Gunny Posted December 12, 2018 Author Popular Post Report Posted December 12, 2018 58 minutes ago, DAB said: my thumb is 1" wide exactly. my hand is 4" wide, my span is 9", and my cubit is 18". i'm good to go. right?? Yes!!!! Whenever we build an ark again! Cal, Grandpadave52, LarryS and 5 others 8 Quote
Popular Post DAB Posted December 12, 2018 Popular Post Report Posted December 12, 2018 32 minutes ago, Grandpadave52 said: Uhhhh...well then how do you guys measure a project after it's done to see if it will fit through the shop door? i'd rather not talk about that incident. almost happened. nice oak standing desk that was going to be too deep, too wide, and too tall to fit out of the basement door. it got finished in the garage.... LarryS, HARO50, DuckSoup and 4 others 7 Quote
Popular Post DAB Posted December 12, 2018 Popular Post Report Posted December 12, 2018 23 minutes ago, Woodbutcherbynight said: Yes!!!! Whenever we build an ark again! thankfully, that was a one-off project. custom, one-off projects always take longer thank planned. 120 years in that case. Gunny, LarryS, Cal and 3 others 6 Quote
Popular Post Artie Posted December 12, 2018 Popular Post Report Posted December 12, 2018 1 hour ago, Gene Howe said: If I were a Carpenter, I'd sing the praises of a tape measure. I'm not a Carpenter and, I can't sing. Nor do I use a tape measure. I thought the second line of that song was “If I were a carpenter, and you were a lady....” If you don’t use a tape measure how do you know how long you TRIED to sing? Dadio, Stick486, Gunny and 6 others 9 Quote
Popular Post Gunny Posted December 12, 2018 Author Popular Post Report Posted December 12, 2018 1 hour ago, Gene Howe said: If I were a Carpenter, I'd sing the praises of a tape measure. I'm not a Carpenter and, I can't sing. Nor do I use a tape measure. I am guessing you speak of using these? Grandpadave52, p_toad, Cal and 4 others 7 Quote
Popular Post lew Posted December 13, 2018 Popular Post Report Posted December 13, 2018 1 hour ago, Grandpadave52 said: Uhhhh...well then how do you guys measure a project after it's done to see if it will fit through the shop door? Let me tell you about the china closet that didn’t fit up the basement steps... Gunny, DuckSoup, Dadio and 6 others 1 8 Quote
Popular Post LarryS Posted December 13, 2018 Popular Post Report Posted December 13, 2018 I've been cleaning my shop. I found 2 tape measures and about dozen pencils. I often wondered what happened to them. I still haven't found a scraper that I used to use all the time. Grandpadave52, Cal, DuckSoup and 2 others 3 2 Quote
Grandpadave52 Posted December 13, 2018 Report Posted December 13, 2018 2 hours ago, Artie said: I thought the second line of that song was “If I were a carpenter, and you were a lady....” If you don’t use a tape measure how do you know how long you TRIED to sing? SNORK!! HARO50 and Cal 1 1 Quote
Popular Post Grandpadave52 Posted December 13, 2018 Popular Post Report Posted December 13, 2018 14 minutes ago, LarryS said: I still haven't found a scraper that I used to use all the time. I'll keep an eye out for it when I clean & reorganize next spring. LarryS, HARO50, Gunny and 2 others 5 Quote
Popular Post lew Posted December 13, 2018 Popular Post Report Posted December 13, 2018 I can never find a pencil and yet... hawkeye10, HARO50, Gunny and 4 others 7 Quote
Popular Post Grandpadave52 Posted December 13, 2018 Popular Post Report Posted December 13, 2018 2 minutes ago, lew said: I can never find a pencil and yet... I'm convinced it's Russian Aliens colluding with Leprechauns, the troll under the bridge and the monsters under the bed & in the closet that are responsible for all missing pencils & measuring devices. It's obvious pencil manufacturers are providing pay-offs to these sinister shop hooligans to disrupt activity in the blink of an eye. LarryS, lew, HARO50 and 4 others 1 6 Quote
Gunny Posted December 13, 2018 Author Report Posted December 13, 2018 3 minutes ago, Grandpadave52 said: It's obvious pencil manufacturers are providing pay-offs to these sinister shop hooligans to disrupt activity in the blink of an eye I'm not much for conspiracy theories, BUT you might be on to something. LarryS, Cal, lew and 1 other 2 2 Quote
Popular Post Gerald Posted December 13, 2018 Popular Post Report Posted December 13, 2018 Won't need an ark next time , find a fireproof bunker. Good idea on the tapes but I like to have one at each work station so I can cross the shop to find where it was actually left. Grandpadave52, Gunny, HARO50 and 4 others 2 5 Quote
