MWTCA January 2018 "What's It" Project
No. 63 Low Angle Jack Plane Woodriver.jpgGrand Prize
We are proud to offer a Woodriver No. 63 Low Angle Jack Plane to this months "What's It" winner. This months "What's It" is sponsored by our supporter Woodcraft Supply.
Originally advertised as a plane for heavy stock removal across the grain, the No. 62 has found a home as a smoother and is quite popular among collectors. The WoodRiver® No. 62 is faithful to the original design, but is almost a full pound heavier at approximately 4.6 lbs. It features a body cast from ductile iron, with a bed angle of 12°, a bubinga tote and front knob, and a high-carbon steel blade with a 25° bevel. The plane measures a little less than 14" in length x 2-7/16" in width and has a 2"-wide blade. (Value $205.00)
(For a full run down on this project and rules please go to: "The Patriot Woodworker and MWTCA "What's It" project")
Ok ladies and gentlemen, we now have our January "What's it" live and ready!
Project details
No further information provided, what you see, is what you have.
Remember, "What's It" is not always woodworking related!
  • Replies 58
  • Views 6.1k
  • Grandpadave52
    Grandpadave52
    Vintage Zip Line handle bars
  • I know exactly what this one is....but I'm not tellin'.
  • Yup! I was running the darn thing from about 10 or 11 years old. My father could never get it started. I would watch him try and start it until it wore him out. When he gave up, worn out and panting f
I know exactly what this one is....but I'm not tellin'.:lol:
Edited by Gene Howe
It is a handle for a special teeter totter
Well shucks, Kelly. You went and spilled the beans.:(:lol:
Edited by Gene Howe
Could be a part of something too gents, and ladies!
Looks like something that handles line, or rope. By itself, or a part of another mechanism or machine. Hmmm
Missing the crank, but it is for flying kites!
Cal
Actually thinking like a wire twister or some such,
Cal
Both sides appear to be the same, same two dowels, same wheel mechanism.
Looks like a cable splicing tool.
Even if it isn't right I like @Grandpadave52 answer.  Looks like fun.  It is another oddity for sure.
Definitely a variation of a barb wire stretcher.
The wire goes into the wheel, through the two dowels and the "toe" of the tool is placed on the post. The stretcher is then levered using the post as the fulcrum point and stretching the wire taught while the wire is tacked to the post. I've used similar configurations, but there were hundreds of variations of this same tool. Good luck finding the specific patent.
In the case of this tool, I'm going to guess that a rope was used on the tool and attached to the wire itself.
Due to the look of the pulley I am thinking it was used in conjunction with a snatch block to move items to heavy to move without extra leverage.  The pins would keep the rope in line with the pulley.
That was my first guess too Bill, but took the "low road answer" instead. After reading your description, I looked again and could see where the rope might route through the pulleys and guides with one end connecting to the wire and the other end tied off to a corner or brace post for leverage. This one is missing the clamp portion which attached to one end of the rope, then to the barb wire. Similar to the picture below which is similar to the style we used...
I suppose it could be a form of an electric fence wire stretcher also which would work similar to the barb stretcher...
I used almost the exact same one as that one above, Dave!
Edited by schnewj
So now you know what happened to it! :rolleyes:
John
well, this is listed as a fence wire twister, so i don't think that's what this is.
Used for a chalk line, back when the chalk came in domed shaped blocks.
like these?
1 hour ago, p_toad said:
like these?
I think I still have a piece of one somewhere; the white color.
