Showing results for tags 'wood carving'.
In the "what's on your lathe" topic I mentioned that I had a piece of brass to make some ferrules. I made around 20 1"od and same for 3/4" od ferrules. Mostly hacksaw and file work and it sure made me wish I had a small metal lathe like Dan. A while back I turned some mallets for a local wood carver and he mentioned he'd like to have a set of handles as well. That's what the ferrules are for. I don't really like commission work but he was pretty adamant he wanted me to do them. Shot him what I thought was a high price and he increased how many he wanted, go figure. He wanted them out of Osage, same as his mallets. Fortunately I had enough to do them. The ferrules are a press fit and that takes some time to get right but once that's done the handles are a pretty simple profile. He said he wanted a set of matching handles, ended up to be 16 total. I told him "matching" was a relative term and there would be minor differences. He said that's why he want's hand made. It is his intention to only use them when he's demoing. 11 more to go, he doesn't know it but I intend to burn his name and a small graphic on the handles. The burn lines will be different on each one to help him identify them if the edge is hidden. Had a minor set back this morning though, blew a tire.
- 12 replies
- ferrule
- wood carving
(and 5 more)
- 13 comments
- hollow form
- wood carving
(and 1 more)
- 3 comments
- 1 review
- amateurs
- wood carving
(and 2 more)
- 2 comments
- hollow form
- wood carving
(and 1 more)
With @IrishWoodCarver, @Steve Krumanaker, our new member @pdexter plus the works that @Dale Felice, @Smallpatch and others I'm probably forgetting are doing could we consider adding a Woodcarving Forum? It would be great to have a place specifically to showcase & share their work? Doing so might entice others who share these talents to join TPW or perhaps already here but not sharing.
- 23 replies
- chip carving
- wood carving
(and 1 more)
- wood carving
- design
(and 1 more)
