Showing results for tags 'skew work'.
Just a little over a week left to reach our goal of $1800. If you haven't gotten your raffle tickets- DON'T DELAY! Our Patriot Turners- @FrederickH salvaged an oak burl and wondered whether we thought it was worth turning. You can probably guess we were 100% in favorite of doing it!! Check out more images and our members comments here What’s Coming Up- Last Friday (June 20) Cindy Drozda's Tool Talk was about cutting threads. She used a dedicated jig for her demonstration. If you missed it, she made it available on YouTube- Click the image for more information and registration For The Newbies- If you are getting ready to turn that first bowl but need some advice on mounting the blank, Mike Peace has some ideas- Sam Angelo follows up with more ways to mount turnings on the lathe- Woodcraft has a great page on their site for turning lessons. If you need ideas on awesome projects, check it out! Click the below image!! Expand Your Horizons- On your tool rack , there's the spindle gouge, the bowl gouge and the parting tool. But, what about that skew chisel gathering dust. Richard Raffan and Tomislav Tomasic have some tips, techniques and ideas for improving our skew skills! Speaking of Richard Raffan, he was recently given the 2025 Honorary Lifetime Award by the AAW- Turning Time With Easy Wood Tools- If you are in the Leesburg, VA are on Saturday, June 28, stop by the Woodcraft store and check out the Easy Wood Tools demo- https://www.woodcraft.com/pages/store/northern-virginia?srsltid=AfmBOooX-T5uZvqRSaE53QE8POZK3Az_uUkkKI4F6AiBz28zxtHegHai Another EWT shared video showing how easily a bottle stopper can be made- AQMKdmjEumcWBsnzATzgqKdhM_B42S3eIyZZnqgeYCBchGv6K1yRedL_mLQVDjURiFkIQvYOXHI2FkUFbc40B6C7.mp4 @Jordan Martindale New Turning Items- Tim Yoder recently reviewed a new CBN wheel for his grinder. Woodcraft has a sale on turning kits and supplies! Click on the image for the link to all the goodies! Highland Woodworking has the Woodslicer Bandsaw Blades on sale-. Click on the image for the link Everything Else- @Gerald asked for some images of the John Beaver wave bowls I am preparing for a demo I am doing in August. This will be a club demo for the local Cumberland Valley Woodturners. These are just some images of the bowls in various stages of development that I will use to show how they are made. The actual production of a bowl, from start to finish takes several days to allow for glue drying, coloring, sanding and finishing. The bowls are roughed out but left a bit thick so that there will be enough "meat" for gluing later in the process Special supports are made to custom fit inside the bowl to provide a way of holding it together while turning operations are done later. The supports are hot melt glued in place. John Beaver uses MDF but I didn't have any. The supports are drilled to accept dowels to maintain alignment. One of the supports is labeled to keep things aligned. The blank is moved to the bandsaw and a wave is cut in two steps. Dowels are inserted and a pressure block added to the tail stock to make sure everything stays in place and aligned. At his point, the bowl could be made with a wave that stands proud of the surface or recessed below the surface. Recessed wave waiting for the squeeze out to gel. The inside of the bowl will have the supports removed and then turned to the final thickness. The extra "meat" in the wall thickness makes sure there is enough surface for a good glue bond when turning the inside to a respectable wall thickness. Safe turning
- 4 replies
- wednesday
- wisdom
(and 27 more)
- wednesday
- wisdom
- woodturners
- raffle
- burl
- cindy drozda
- threads
- jig
- swat
- mike peace
- bowl blank
- mounting
- sam angelo
- wood mounting
- woodcraft
- projects
- turning supplies
- skew work
- richard raffan
- tomislav tomasic
- easy wood tools
- detailer
- tim yoder
- cbn
- highland woodworker
- woodslicer
- bandsaw
- john beaver
- wave bowl
