Showing results for tags 'drive centers'.
More rain to fill the PA potholes Our Patriot Turners- @Fred W. Hargis Jr is making progress on his coin displays. He is turning the pedestals for each coin and ran into a little problem and asked our advice. Check out Fred's post for our members suggestions. I finally dug out the chainsaw and went for some sycamore. Cut everything on site instead of manhandling big chunks of logs. A bunch of approximately 6 x 6 pieces and some a little bigger. Ends sealed with old Titebond glue. Seven of these pieces have been rough turned, 4 soaked and in the drying box and 3 more in the soak now. I was surprised how much the log had spalted since the last time I cut from it, especially since it was not in contact with the ground. What’s Coming Up- If you missed Cindy Drozda's tool talk with Emma Cook, it is available on YouTube- For The Newbies- From Tomislav Tomasic on the importance of tool rest positioning- Expand Your Horizons- No Longworth chuck, no Cole Jaws? No problem! Sam Angelo demonstrates how to finish off the bottom of a bowl without those special chucks. Spindles, bowls, hollowing-- been there, done that?? But have you turned a Jelly Fish?? Carl Jacobson shows us this turned art work- Turning Time With Easy Wood Tools- Easy Wood Tools has a great selection of accessories for holding pieces on the lathe. For the headstock, besides their awesome Easy Chuck, they have faceplates, faceplate rings and drive centers. Faceplates- Faceplates are available for lathes with headstock spindles threads of 1 x 8, 1.25 x 8, M30 x 3.5 and M33 x 3.5. With diameters ranging from 2" to 4.5". The faceplates have a large number of holes to ensure secure mounting even on rough surfaces. Faceplate rings- The faceplate rings are machined from cold rolled steel. These heavy rings will work with most 4 jaw chucks. These are available in 3, 4.5 and 6 inch diameters. As with the EWT faceplates, the large number of holes provides secure mounting on uneven surfaces. With faceplate rings, there is no need to replace the chuck with a faceplate. Drive Centers- Being able to mount spindle work without removing your chuck can save time. EWT offers two styles of chuck mounted drive centers. 4 Prong- This heavy duty center offers a retracting point for easy centering and will work with most chucks. Multi-Spur As with the 4 prong drive center, the retracting point makes for easy centering and will fit most chucks. EWT hasn't ignored the tailstock either. Live Center- Standard #2 Morris taper with a 3/4 x 10 threaded nose for additional adapters. The center point position is adjustable. Stabilization Cones- Available in 1.5" and 4" diameter with 3/4 x 10 threads Some of these items are demonstrated and reviewed by Carl Jacobson- Another well known woodturner demonstrating EWT tools- Upcoming EWT live demonstration- Be sure to check you local Woodcraft store for additional live EWT demos during the month of June. @Jordan Martindale New Turning Items- Everything Else- From Ron Brown's newsletter Opportunity "There is little opportunity when nothing changes...but with change comes opportunity." My daughter is brilliant! As a scientist working in a large laboratory developing poultry vaccines, change was constant: personnel, protocols, facilities, and equipment. It bothered her every time. My counsel was always to welcome changes because there is little opportunity when nothing changes. But with change, opportunity always comes, and it always did. For the hobby woodturner, this speaks to stagnation. If your techniques remain the same, your projects look the same, and your understanding of wood and tools doesn't evolve, your opportunities for growth and enjoyment are limited. You might become proficient at a few specific tasks, but you'll likely hit a plateau. • Limited Skill Development • Repetitive Projects • Missed Learning • Lack of Innovation "...but with change comes opportunity." This is the exciting part! Change, even when it feels a little daunting, opens doors to new possibilities and growth in your woodturning journey. • Learning New Skills: Experimenting with different wood species or mastering a new finishing technique (like CA), expands your capabilities and opens up new project possibilities. • Exploring Different Project Types: Moving beyond simple bowls to tackle complex spindle projects, or even furniture components, can lead to greater satisfaction. • Adopting New Tools: Investing in a new tool, jig, or fixture, even a seemingly small one, can revolutionize your workflow and the types of projects you can undertake. • Discovering New Materials: Experimenting with epoxy resin, metal inlays, or even incorporating non-traditional materials into your woodworking can lead to unique and exciting results. • Sharing and Learning from Others: Engaging with the woodturning community online or in person exposes you to different approaches, ideas, and critiques, fostering growth and new opportunities for learning. Other key precepts to consider: • Master New Forms: Progressing beyond basic shapes to complex forms (hollow vessels, segmented/off-center turning) provides significant skill development. • Experiment with Different Woods: Exploring various wood types (hardwoods, softwoods, figured, green) reveals diverse textures, colors, and challenges. • Learn New Tool Techniques: Utilizing different gouge profiles, scrapers, and specialized tools expands achievable effects and forms. • Explore Embellishments: Incorporating carving, burning, painting, or resin inlays adds artistic dimensions to turned pieces. • Improve Sharpening Skills and Techniques: Continuously refining tool sharpening and lathe stance improves cut quality, control, and intricacy. • Embrace New Technologies: Integrating modern technologies like laser engravers and advanced finishes offers new creative possibilities in woodturning. Don't be afraid to step outside your comfort zone at the lathe. Embrace the challenges that come with learning new techniques, experimenting with different materials, and exploring new forms. Each change, each new skill acquired, each different wood you turn, is an opportunity to grow as a craftsman, to create more unique and satisfying pieces, and to deepen your enjoyment of this excellent craft. Safe turning
Wow, where did the month of April go?!?!?! Our Patriot Turners- @RustyFN gave us an update on his latest basket illusion vase. It is absolutely gorgeous!! Head on over to Rusty's post and see what our members had to say- What’s Coming Up- If you missed Cindy Drozda's Live Tool Talk, she has it uploaded to her YouTube Channel- Click on the image for the link to more information and registration- https://www.woodcraft.com/pages/store/dayton https://www.woodcraft.com/pages/store/raleigh For The Newbies- A short video from Tim Yoder on choosing a drive center- Expand Your Horizons- Mike Peace demonstrates a multi axis turning with a beautiful piece of cherry burl- Turning Time With Easy Wood Tools- Easy Wood Tools has settled into their new digs! Click on the calendar for the link to the interactive page. The Easy Wood Tools Detailers are typically used to create fine lines on a turning. They can also be used to shape tiny details in objects like finials. The Detailers come in two configurations. The Easy Detailer, which uses the standard Ci4 cutter or the negative rake Ci4-NR cutter And the Easy Micro Detailer, which uses the Ci7 cutter or the negative rake Ci7-NR cutter This short video from Craft Supplies USA demonstrated the Easy Detailer This video, from Tracey Malady uses the Easy Detailer and Micro Detailer to help shape a finial- When using this tool, the best surface is created by having only one side of the cutter in contact with the material, at a time, as the cutter goes deeper into the turning. New Turning Items- Tomislav Tomasic reviews his new Vicmarc VL300 Wood Lathe. That sure is a nice piece of equipment, Everything Else- Safe turning
Picked up a wild dose of the back door trots. Our Patriot Turners- @keithlong did his first craft show and picked up some additional turning work. Keith is looking for curly Koa. Check out his post and see if you can point him in the right direction! @Ron Altier picked up some cypress from his local thrift store. Ron is our resident ornament maker and this one doesn't disappoint! Check Ron's post for the wonderful comments from our members- @Gerald posted a cart/rack for holding his new Jaho jig. This jig is bigger than I realized and certainly heavy! More pictures and information about the build in Gerald's post- @kreisdorph put his new Rikon lathe through it paces! He tells us about it here- @smitty10101 is working on a bowl from a board. He has some questions about cutting the angles and a few other things. I know some of our turners use this technique, I you can help Smitty out, head on over to his post! In our "Good Monday Morning" forum, @John Morris posted a really amazing turning video. Checkout some of the custom made jigs for applying finish! We've had some entries on or continuing posts of ON/OFF your lathe From ON- @Gerald posted this one Catchup up on all the comments here- And from OFF- @Gerald, @kreisdorph and @lew Head on over to the topic and checkout the comments What’s Coming Up- This was last week but if you missed it, Cindy Drozda posted the video of her "Tool Talk"- https://streamyard.com/watch/CyvKGNCGNujG For The Newbies- A video from Mike Peace on the various types of drive centers- Sam Angelo demonstrates the use of the spindle gouge. From Tim Yoder on the roughing gouge- Facebook video.mp4 Expand Your Horizons- Lyle Jamieson discusses balancing the grain and color when turning a bowl- For some reason this video isn't showing up for me. Here is the YouTube link https://youtu.be/VtHVrf-1xlQ?si=n28y_i4yw_IKFfTY Alan Stratton makes a unique box that looks like a stacking toy! An interesting design on a cherry bowl by Kent Weakley Jim Rodgers makes a really neat one piece pen- New Turning Items- https://nilesbottlestoppers.com/product/threaded-rings-for-urns/ Everything Else- Safe turning
- 6 replies
- craft show
- wisdom
(and 37 more)
- craft show
- wisdom
- wednesday
- woodturners
- ornament
- cypress
- cart
- jaho jig
- new lathe
- techniques
- bowl from a board
- rikon
- moulthrops
- questions
- bowls
- todd raines
- sharing
- hollow forms
- cindy drozda
- wit
- mid atlantic symposium
- jimmy clewes
- course
- mike peace
- sam angelu
- spindle gouge
- drive centers
- roughing gouge
- lyle jamieson
- tim yoder
- bowl design
- alan stratton
- wood box
- kent weakley
- cherry bowl
- jim rodgers
- one piece pen
- niles bottle stoppers
- bronze rings
