October 2Oct 2 comment_381550 Hi, probably simple question but I like to use carnauba on smaller turns the problem I have is the bars I've gotten are as hard as rock practically and other is usually a soft wax mixture. When I try to use the bar it leaves ring marks on the wood because its so hard it not from a lack of melting. Anybody point me to a place that has bars similar to beeswax or do they simply not exist? Thanks Report
October 3Oct 3 comment_381563 I’ve been using the carnauba wax from RMP , it’s not quite as soft as bees wax but easy enough to apply. It seems expensive but a little bit goes a long way. Report
October 3Oct 3 comment_381564 I would suggest that you could soften the wax you already have by shaving some of it into a small jar and adding mineral spirits until you get the consistency you want. (note, allow sufficient time for the spirits to dissolve the wax ) Hope this helps. Report
October 3Oct 3 comment_381565 3 minutes ago, Rusty S said:I would suggest that you could soften the wax you already have by shaving some of it into a small jar and adding mineral spirits until you get the consistency you want. (note, allow sufficient time for the spirits to dissolve the wax ) Hope this helps.That's what I do with beeswax. Report
October 3Oct 3 Author comment_381574 Thanks all, I use beeswax most of the time I actually have a bee keeper near by and have it straight from the source probably not really much different than what you buy. I may try softening it. I am going to look into RMP I dont use it that often because of the poor results but would like to. Report
October 3Oct 3 Author comment_381575 I checked out RMP but all I found were paste waxes but maybe I was misssing something, most were a mixture of other waxes, I already have several kinds of those, wood and butcher board sealers but on the lathe I'm looking for a bar like pure beeswax only softer bar of carnauba. It may not exist. I will give the softening a go. Thanks for your suggestions. Report
October 3Oct 3 comment_381578 Don't know if this will help or not but I'll try. I make up a cutting board 'butter' by heating mineral oil and then melting beeswax in it. If it gets too thin, I just add more wax til it gets to the consistency I want. I generally try to get the consistency of Vaseline for rubbing onto boards. You may be able to do something like this with a very small amount of oil and a bigger batch of wax and then mold it into a stick shape. Report
October 4Oct 4 comment_381588 Better than carnuba is microcrystalline wax. The thing about using the bar directly is to use high speed and move it quickly. Best way to use carnuba is with a Beall buff system. It works really well doing that.Now for soft but probably not quite as effective try Heating with mineral oil. No idea how much to put in but a friend did this with microcrystalline wax. As to effectiveness all waxes will require future reapplication. Carnuba will show fingerprints. Using microcrystalline wax , such as Renaissance Wax does not show fingerprints. Report
October 5Oct 5 Author comment_381639 I have Renaissance wax but didn't have to good of luck and without looking I don't know if it is food safe on my bowls I only use food safe finishes. I'm going to try the mineral spirit or oil see if I can make my own bar. Report
October 5Oct 5 comment_381640 12 minutes ago, Geezer said:I have Renaissance wax but didn't have to good of luck and without looking I don't know if it is food safe on my bowls I only use food safe finishes. I'm going to try the mineral spirit or oil see if I can make my own bar.This is the recipe I use for cutting boards and bowls-How to Make Your Own FinishYou can easily make your own wood butter or balm at home using a simple ratio of 1 part beeswax to 4 parts mineral oil (by volume or weight).Ingredients:1 oz Beeswax pellets or grated wax4 oz 100% pure, food-grade mineral oil Instructions:Set up a double boiler on low heat (or use a dedicated small crockpot).Pour the mineral oil and beeswax into the container.Heat gently and stir occasionally until the beeswax melts completely into the oil (about 20–30 minutes).Pour the warm liquid mixture into small metal tins or glass jars and let it cool undisturbed for 30–45 minutes until it solidifies into a soft paste. For rolling pins I just use mineral oil. You can get food safe mineral oil in the Pharmacy aisle at the grocery store. Report
October 5Oct 5 comment_381641 47 minutes ago, lew said:This is the recipe I use for cutting boards and bowls-How to Make Your Own FinishYou can easily make your own wood butter or balm at home using a simple ratio of 1 part beeswax to 4 parts mineral oil (by volume or weight).Thanks @lew . I did an experiment this summer and found the same ratio. I tried using a microwave without success. But the SC summer sun did a great job with just an occasional stirring. Report
October 5Oct 5 comment_381642 14 minutes ago, JimM said:I tried using a microwave without successI have used the microwave- when my wife is not home Report
October 30Oct 30 comment_382299 @Lew previously you gave us the recipe for cutting board wax4:1 ratio.Can you enlighten me as to how watery/solid the result should come out?creamy?liquid?solid?thkssmitty Report
October 30Oct 30 comment_382300 @smitty10101 , It's kind of buttery. If you find it too soft add an small amount of beeswax, too thick add a little mineral oil. I do mine in the microwave (when the wife isn't home) heat for about a minute to start. Then heat a little more watching for the wax to start melting. Swirl the container to speed up melting. Reheat, swirl until completely melted. Let cool. If consistency isn't quite right add wax or oil and repeat. Report
October 30Oct 30 comment_382301 Microwave----- yeah, she has knives & several other instruments of death!!!been using a SMALL crock pot, just about big enough to do a double batch.1st batch came out pretty solid b/c I added more wax pellets2nd batch also solid but at exactly 4:1reason for the question is b/c I have various BOOS products and 2 of them are liquid and the butcher block wax is kinda creamy,so I was wondering what a home brew should look likesmitty Report
October 30Oct 30 comment_382302 I just eyeball it. I've had some that was pretty solid, too. Just added more oil. Saw the BOOS stuff at a demo once. It was a little creamer then what I mix up. Maybe they blend theirs. Also, I buy the beeswax directly from a local "bee product" place. Tiny little store run by a Mennonite lady. So maybe it is processed differently. Report
October 30Oct 30 comment_382307 4 hours ago, smitty10101 said:@Lew previously you gave us the recipe for cutting board wax4:1 ratio.Can you enlighten me as to how watery/solid the result should come out?creamy?liquid?solid?thkssmittyI'll chime in here - peanut butter. That's how a tile guy described properly mixed grout, and it seems to work for me. Or, room temperature butter. Report
October 30Oct 30 comment_382308 1 hour ago, JimM said:Or, room temperature butter.so more solid/creamy than runny/liquid? Report
November 1Nov 1 comment_382359 On 10/30/2026 at 6:07 PM, smitty10101 said:so more solid/creamy than runny/liquid?Maybe it depends on the application. I'm applying it by hand on cutting boards. I've found that it tends to clump up if it's too thick.Applying while the piece is on the lathe may be different. Because of heat generated by the turning?? Report
