Stacy N Posted November 18, 2024 Report Posted November 18, 2024 Hello! I bought a number of old wooden dough bowls when we were stationed in Europe, and they are in need of some TLC. I know the person I bought most of them from treated them with wax. Does anyone have a favorite wax? Do you just apply and buff with an old rag or use an electric polisher? John Morris, lew and Grandpadave52 3 Quote
John Morris Posted November 18, 2024 Report Posted November 18, 2024 Howdy Stacy, are you using your dough bowls for actual foods? Stacy N, Grandpadave52 and lew 3 Quote
Stacy N Posted November 18, 2024 Author Report Posted November 18, 2024 Hi John -- great question! The big ones will definitely not have food in them. The small ones I'd ideally like to have the option of putting bread in. The last time I was searching for non-toxic wax options, I found Daddy Van's (I think that's the name), but it's not terribly easy to buff off, so I'm hoping there's either a better wax option or a better buffing technique than an old t-shirt. ;-) Grandpadave52 and lew 2 Quote
John Morris Posted November 18, 2024 Report Posted November 18, 2024 Stacy, I use this for some of the bowls I have made, and some carved spoons I've made. Howard Butcher Block Conditioner WWW.WOODCRAFT.COM Howard Products® Butcher Block Conditioner is specialized care for butcher blocks, cutting boards, wooden bowls and utensils. The... Stacy N and Grandpadave52 2 Quote
Stacy N Posted November 18, 2024 Author Report Posted November 18, 2024 2 minutes ago, John Morris said: Stacy, I use this for some of the bowls I have made, and some carved spoons I've made. Howard Butcher Block Conditioner WWW.WOODCRAFT.COM Howard Products® Butcher Block Conditioner is specialized care for butcher blocks, cutting boards, wooden bowls and utensils. The... Awesome -- thanks so much! I'll try it! John Morris and Grandpadave52 2 Quote
lew Posted November 18, 2024 Report Posted November 18, 2024 Bread bowl for serving or bread bowl for raising dough! For serving, I'd use a mixture of beeswax and mineral oil. For raising I'd just use a light coating of mineral oil and wipe it off. Then just flour the heck out of it! Stacy N, John Morris, Headhunter and 1 other 4 Quote
Stacy N Posted November 18, 2024 Author Report Posted November 18, 2024 6 minutes ago, lew said: Bread bowl for serving or bread bowl for raising dough! For serving, I'd use a mixture of beeswax and mineral oil. For raising I'd just use a light coating of mineral oil and wipe it off. Then just flour the heck out of it! Thanks, Lew! Just for serving. ;-) John Morris and Grandpadave52 2 Quote
Popular Post lew Posted November 18, 2024 Popular Post Report Posted November 18, 2024 22 minutes ago, Stacy N said: Thanks, Lew! Just for serving. ;-) You can make your own finish for the beeswax/mineral oil stuff- which is basically the butcher block conditioner @John Morris mentioned. I do mine in the microwave using an old Tupperware container (or similar). I make about a cup at a time. Use about 1 cup of mineral oil and about 1/4 cup of beeswax. There's a "Bee" store near me that is run by a Mennonite family. I buy a block of beeswax and shave it down so it melts easier. Heat for a minute or 2 then swirl the oil to accelerate the melting. Don't boil the oil! Just take your time. Heat, swirl, repeat until the wax is completely melted. When the mixture cools, it will "congeal" and depending on the ratio of wax to oil will determine the consistency. I like mine to be like soften butter easy to apply with a rag and wipe off after a few minutes. You can play with the ration until you find a consistency that works for you. HandyDan, DuckSoup, Headhunter and 3 others 3 3 Quote
John Morris Posted November 18, 2024 Report Posted November 18, 2024 15 minutes ago, lew said: You can make your own finish for the beeswax/mineral oil stuff- which is basically the butcher block conditioner @John Morris mentioned. I do mine in the microwave using an old Tupperware container (or similar). I make about a cup at a time. Use about 1 cup of mineral oil and about 1/4 cup of beeswax. There's a "Bee" store near me that is run by a Mennonite family. I buy a block of beeswax and shave it down so it melts easier. Heat for a minute or 2 then swirl the oil to accelerate the melting. Don't boil the oil! Just take your time. Heat, swirl, repeat until the wax is completely melted. When the mixture cools, it will "congeal" and depending on the ratio of wax to oil will determine the consistency. I like mine to be like soften butter easy to apply with a rag and wipe off after a few minutes. You can play with the ration until you find a consistency that works for you. That's perfect Lew Headhunter and Grandpadave52 2 Quote
Gerald Posted November 19, 2024 Report Posted November 19, 2024 I use the Beeswax/Mineral Oil on my cutting boards. On my Dough bowl I used Mineral oil 8 years ago , but since that time nothing added as the oil in bread does it all. John Morris, HandyDan, Grandpadave52 and 1 other 4 Quote
Popular Post kmealy Posted November 19, 2024 Popular Post Report Posted November 19, 2024 (edited) Just as a side note, I got from my parents' estate the wooden bowl that we used for shaping butter when I was growing up (we had dairy cows until I was about 16). It still smells like butter. Edited November 19, 2024 by kmealy Headhunter, DuckSoup, Grandpadave52 and 2 others 4 1 Quote
Woodman Posted December 22, 2024 Report Posted December 22, 2024 On 11/19/2024 at 12:04 AM, Gerald said: Beeswax/Mineral Oil Currently I use C.S.Johnson Paste Wax, which is paraffin in a carrier (solvent) of naphtha. Hydrocarbon-based solvents are on their way out, it seems. D-Limonene (Orange Oil Limonene Extract) is a natural solvent, I'm hearing. One woodworker tells me he uses it to clean resin from the inside of his wood plane. A local mill shop makes and sells a beeswax paste wax they use on everything, using orange solvent as the carrier. On my New Years Resolutions list (year 2027 at this point) I'm going to try making this type of wax. And keep the mineral oil and extra-virgin olive oil as backup plans. Grandpadave52 and Gerald 2 Quote
lew Posted December 22, 2024 Report Posted December 22, 2024 3 hours ago, Woodman said: And keep the mineral oil and extra-virgin olive oil as backup plans. I've read that olive oil can turn rancid over time. Coconut oil, used by a chef friend on his wooden rolling pins, has antibacterial properties. Not sure where he gets it. Grandpadave52 and Woodman 2 Quote
Fred W. Hargis Jr Posted December 22, 2024 Report Posted December 22, 2024 (edited) Here's what my wife uses (coconut oil, for cooking). Well crap, the link won't work: Edited December 22, 2024 by Fred W. Hargis Jr lew and Grandpadave52 1 1 Quote
lew Posted December 22, 2024 Report Posted December 22, 2024 19 minutes ago, Fred W. Hargis Jr said: Here's what my wife uses (coconut oil, for cooking). Well crap, the link won't work: @Fred W. Hargis Jr Thanks, Fred! Grandpadave52 1 Quote
