Posted (edited)
Ditto on Fred’s advice. I have the 16” version of your planer and you can definitely jointer 9’ lumber and get it close enough to glue up. What type of Bessey and pony clamps do you have ? If they are 3/4” pipe clamps they are more than enough. Figure one clamp per foot of board. I don’t know what your shop layout is but you can make very effective extension tables for the Hammer jointer. You can also buy them but I think they are about $500 each. I made mine for about $50. Happy to send photos if you want. My process for getting perfect glue joints is first jointer them as straight as you can. Without an extension table you will need a second set of hands. The second part of the process is to rip them on the table saw. You need to make a minimum of a 48” fence extension for your saw. This allows you to straighten them even further. When you rip them you want to take a maximum cut about 1/32 of an inch off each side. As you cut them put a mark on the top of each board and keep that side up for both cuts. During the gluing process you will invert each board so that the marks you made will be one up and one down on alternating boards. This compensates for any small inaccuracy that your saw may have and prevent any arcing or bowing during the gluing process. If you have a biscuit joiner it will make the glue up a lot easier. Dominoes even better.
Paul
Edited by Masonsailor
Posted
I know a man that made a conference room table 16' long 5' wide and 6" thick.  He joined sycamore flitches from his sawmill to make the top.  These were too big and heavy to move through a jointer or planer.  Instead he used a track saw to run the joint between the flitches.  Lined up perfectly.  Looked like it had been fit with a jointer.
.40
Posted
19 hours ago, Gene Howe said:
Yes!!! Please do that. Much appreciated.
I'll second that request for the pics!
  • Like 2
  • 4 months later...
Posted
I must have posed the question badly/
I am concerned about the small imperfections in the  edge jointing and the  impossibility of pulling  very thick lumber together.
I have pieces that are over 2" thick and 8 or so inches wide ( based on a ratio derived from  the norm of 3/4' thick and 3" wide boards)
I'm somewhat concerned that no amount of clamp pressure will move that much wood. but I ant to build the table up from those pieces.
Posted
On 8/19/2023 at 7:21 PM, Cliff said:
Should I just go for it and see?
Cliff, go for it and see, with a dry fit, whaddya got to lose?
  • Like 3
Posted
What have I got to lose?  A little effort is all.  Yah I'll go for it.
  • Like 3
Posted
 Yep. And some experience gained. :)
  • Like 2
Posted
2 hours ago, Cliff said:
yup
Your jointer must have at least an 8 foot bed. I'd set up an infeed and outfeed roller at about 4 feet from each end that should support the pieces as you run them thru.
  • Like 3
Posted
By the way Cliff, I have clamped some pretty big thick boards with my pipe clamps, slab long grain to long grain after jointed and did it successfully, I'd set my pipe wrench on the turn handles for leverage and it worked really well. You can really "wrench" down on those handles, I've given it a whole lot of pressure by getting that extra turn or two in that I couldn't do with my bare hands and close gaps beautifully.
Posted (edited)
14 hours ago, lew said:
8 foot bed
that part's easy  I've just never glued up this thick before and I want seams so tight that  one can't see 'em.
Edited by Cliff
  • Like 2
  Only 75 emoji are allowed.
