July 31, 20233 yr Author Popular Post comment_318489 Monday in the shop and nothing went wrong? So...PIP time...still have a bit of Final Sanding to do...but.. Lid sit flat Both drawers are done...felt to be installed, after the Witch's Brew goes on... Need to file/sand around the latch...Square is for scale.. Hinges? With all the screws "Clocked" Case needs a set of feet, to elevate it? So...Mitre Box & Saw...the Cordless No. 72c Millers Falls model Had to keep changing it from 45 degrees, to 90 degrees and back... Bandsaw to cut a fancy end.. Then sand all these "rough cuts"...add a dab of glue...and moosh them around a bit, until they stick in place... Waiting on the glue to cure.. Then sand these level. Clean up the blobs of glue...with a sharp chisel. Almost done...on the last day of July! Stay tuned Report
July 31, 20233 yr comment_318490 20 minutes ago, steven newman said: Almost done...on the last day of July! ...and a beautiful job, too! Report
July 31, 20233 yr comment_318492 38 minutes ago, steven newman said: Almost done...on the last day of July! No sweat...well probably some last week; anyways well done. Don't forget the Dungeon Brand. Report
July 31, 20233 yr Author Popular Post comment_318503 PIP #2? Front view...with a coat of Witch's Brew.. Debate is whether Amber Shellac, or Clear Gloss Poly for the top coat... Raise the lid ( still hunting a small chain) Top has been "Greened" Top drawer, too Added a divider to the bottom drawer....was down to bits & pieces of green.. Feet details? Feet have been planed until the case sits level, without rocking.... Waiting on the Witch's Brew to finish drying...has been wiped down as I went... Otherwise...I think this is done? At least I am down to the "Punch List"... Next? Will try to load this thing up...as soon as I can round up all the lay out tools that will fit in here... Stay tuned Report
August 1, 20233 yr comment_318527 9 hours ago, Grandpadave52 said: Project for July ✓ You called it early on Dave 16 hours ago, steven newman said: Otherwise...I think this is done? At least I am down to the "Punch List"... Next? Will try to load this thing up...as soon as I can round up all the lay out tools that will fit in here... Great little "machinist chest" Steven. What are the dimensions of it? Report
August 2, 20233 yr Author comment_318600 Size of this little box? Show and tell time...with the Blue Grass BG46 Ruler.. BTW, these 2 items were TOO big.. So..Height? About 5-1/2", counting those "big feet" Width? About 9" or so...depth ( front to back) About...6-1/2" counting the front porch... Chain has been added.. And things are filling up...May add that plaque to the lid? A Freebie from Lost Art Press....might just become my Shop's Motto? Items IN the box? Top compartment.. Top drawer ( was trying NOT to set things on top of other things)..and Not much down in the bottom drawer..yet...Blue cases are Pencil leads.. Fancy ruler...anyone know this Brand Name? ( I do...) Report
August 3, 20233 yr comment_318612 5 hours ago, steven newman said: Fancy ruler...anyone know this Brand Name? ( I do.. Yep. Blue Grass Hardware, Louisville, KY. Have a few Blue Grass Items. Some I bought new. Report
August 3, 20233 yr comment_318613 Great box. I have my calipers on magnets in front of the lathe since I use them so much. Report
