Posted
"Lost my virginity" & you quit smoking, that had to be tough;).
 IMO getting the feel for a new saw or blades by cutting natural items is best, cactus, trees, leaves, no straight lines in nature. Nice design Gene.
Posted
Thanks, Bob. 6 weeks without a cigarette. Cravings have ceased. But, following a pattern line, straight or crooked, isn't any easier. You are right, though. Cacti, especially Saguaros ain't too difficult. I'm a long ways fom cutting a rose, though.
  • Like 3
Posted
Thats good for your entry in to scroll sawing. I doubt if I did that good.
  A good tip. I would attach Arizona to the back of the cactus with some very small brads so easy to take apart,, which I predrill the holes with a drill bit a hair smaller than the brad, then when the one line is cut between the two pieces the line will be the same on both pieces for a good fit whether you sawed straight or curvy....
    You can use a bottom piece just long enough where it will attach to the top board, then so you are sawing flat pieces add a little piece of wood to the other side of Arizona.
  • Like 3
Posted
Thanks, Jesse. I stacked the 1/2 (cactus) on a 1/8 panel then cut it all. Used double sided tape. The cactus nestled right in the 1/8. Like the first time I lost my virginity, this was a clumsy attempt. :unsure: Neither attempt resulted in a keeper. :rolleyes:
  • Haha 2
  • Amazing 1
Posted
Gene I have a couple of ideas for your next step. I'll try to post a picture or two in a day or two...... Replacing a hydrant out side I ran over with the mower. The ground is harder than concrete so it might take a few months for the repair for my body don't like that kind of treatment any more..
  • Like 3
  • 1 month later...
Posted
Lew, thanks for realigning the picture.  Did not notice the state outline until you turned it.
Not ready for production work, Gene??????  I hear that is what CNC and Laser machines are now the "go to" machines.  That being said,  The just an NOT do what we do on our eye-hand coordination creations.  Great job.
  • Like 2
  Only 75 emoji are allowed.
