PeteM Posted July 11, 2021 Report Posted July 11, 2021 I finished up some lap joints on pine 1x2, and realized my bandsaw blade was twitching. How'd I do this? Is there a way to bend it back? (Red line added for clarity) It really looks wicked when running. (picture is composite of the two bends, which are adjacent as shown) FlGatorwood, DuckSoup and Cal 3 Quote
lew Posted July 11, 2021 Report Posted July 11, 2021 Wow! Did you notice any vibration when you were making the cuts? It looks like deformation is across the width of the blade! Is the blade new? Cal and FlGatorwood 2 Quote
lew Posted July 11, 2021 Report Posted July 11, 2021 Sorry I see you mentioned twitching. Am I incorrect is saying the deformation is across the width of the blade? Cal 1 Quote
PeteM Posted July 11, 2021 Author Report Posted July 11, 2021 Yes, deformation is width, IOW blade viewed side-on. Viewed looking into the teeth, not deformed. Cal 1 Quote
PeteM Posted July 11, 2021 Author Report Posted July 11, 2021 4 hours ago, lew said: Wow! Did you notice any vibration when you were making the cuts? It looks like deformation is across the width of the blade! Is the blade new? I did not notice the vibration while cutting; saw it afterward. The blade has about total 2 hours cumulative use. Cal 1 Quote
Gene Howe Posted July 11, 2021 Report Posted July 11, 2021 Pete, possible causes might include 1. Upper guides set too high and/or 2. Not enough blade tension. 3. Twisted during a previous cut. 4. Damaged while off the machine. What is the blade width, tpi? Cal 1 Quote
Smallpatch Posted July 11, 2021 Report Posted July 11, 2021 Could someone have pushed it off the wheels while sawing something? And not told you about it. Maybe just put it back on and kept using it??? This would be about the only time the blade would have enough speed to bend with a crease. My little Sears 12" band saw using 1/4 and 1/8" blades come off quite often but have never bent unusable! Seems like I got out of sorts because I could not fold it up like when it was new in a small roll and I stomped it a few times and bending it in a few places. Other wise my wood working episodes are usually calm and enjoyable. Gerald, HARO50 and Cal 3 Quote
lew Posted July 11, 2021 Report Posted July 11, 2021 Like @Smallpatch, I always have trouble getting the blades twisted back into to little circle orientation that they were shipped in. Could it have gotten bent from that? From the photo, it looks like a pretty narrow blade, itf that's the case, I'm leaning towards @Gene Howe's ideas 1 and 2. Cal 1 Quote
Popular Post PeteM Posted July 11, 2021 Author Popular Post Report Posted July 11, 2021 10 minutes ago, lew said: Like @Smallpatch, I always have trouble getting the blades twisted back into to little circle orientation that they were shipped in. Could it have gotten bent from that? From the photo, it looks like a pretty narrow blade, itf that's the case, I'm leaning towards @Gene Howe's ideas 1 and 2. I have never mastered the whole BS blade folding thing (and I have the scars to prove it!). I store the blades unfolded (hang them on the wall, separated). I also thus tend to use the same blade for everything! It's a 3/16" blade, and 4 tpi. I'm the only user. BS is Craftsman (ie, Rikon) 10". Max cut height 4-5/8. I am convinced I did something, but puzzled as to what it was. Ah well, I need more packing material from Amazon anyway. HARO50, lew, HandyDan and 2 others 4 1 Quote
