April 6, 20205 yr 22 hours ago, Gene Howe said: It's beautiful as it is. But, for protection, maybe a few coats of oil based satin poly. Gene, you wouldn't recommend a coat of shellac first to seal the knots?
April 6, 20205 yr 26 minutes ago, Cal said: Gene, you wouldn't recommend a coat of shellac first to seal the knots? Knot a bad idea, Cal. Didn't consider that. My experience with soft woods is very limited. Not to mention, my finishing techniques are even more so.
April 11, 20205 yr Author Popular Post well here is as far as I got for now,used Tongue oil on outside of chest ,leaving inside alone,took top apart cleaned it up ,planed alittle off top am bottom,went with flat top,applied epoxy to top,just waiting to dry an put back together
April 11, 20205 yr That's, for sure, not gonna warp again. Although, you might consider a finish on the bottom side before assembly.
April 11, 20205 yr Looks good and as @Gene HoweH. Said it won't warp again. Definitely put some finish on the bottom.
April 12, 20205 yr 11 hours ago, Woodbutcherbynight said: Looks good and as @Gene HoweH. Said it won't warp again. Definitely put some finish on the bottom. Ditto.
April 12, 20205 yr Author yes will put a finish on bottom of top,epoxy didnt set like I wanted ,found out old shop is UNlevel lol,but it still looks good
