February 14, 20206 yr comment_218534 I was wondering, if I could expand the turning capacity of my Shopsmith, by installing longer way tubes, if I had way tubes say a foot longer, or even 6 inches, I wonderful if there would be a negative by doing this, will the rest of the machine work well? As long as I have the ceiling height for Drill Press mode? Will the longer way tubes sag? Any feedback is greatly appreciated. Report
February 14, 20206 yr comment_218567 John, here's a thread on the SS forum that might answer your questions. Longer tubes Report
February 14, 20206 yr comment_218568 This video handles it pretty well. I would also add another mount/leg give it the extra support. An adjustable leg would be necessary for a roll around unit. Report
February 14, 20206 yr Author comment_218595 1 hour ago, HandyDan said: This video handles it pretty well. I would also add another mount/leg give it the extra support. An adjustable leg would be necessary for a roll around unit. Dan, that is flippin awesome, I really like that, this way you could leave the set up factory standard, and just add the extension when I need it. I was originally thinking of a permanent alteration, like replacing all the tubes with long ones, but to just slide that extension on like that, well that's even better IMO, I think it's best to leave factory fit alone when possible, and a temp bolt on alteration like this is the ticket. Thanks Report
February 14, 20206 yr Author comment_218597 1 hour ago, Gene Howe said: John, here's a thread on the SS forum that might answer your questions. Longer tubes Gene, appreciate it much, reading now! Report
February 14, 20206 yr Author comment_218633 @HandyDan, upon closer examination, the extension in that video won't work. My 520 doesn't have the open ends at the tubes like the 10e's do. Report
February 14, 20206 yr comment_218636 @John Morris, Check this guys approach. http://www.vintagemachinery.org/photoindex/detail.aspx?id=964 Edited February 14, 20206 yr by Larry Buskirk Report
February 15, 20206 yr Author comment_218638 25 minutes ago, Larry Buskirk said: @John Morris, Check this guys approach. http://www.vintagemachinery.org/photoindex/detail.aspx?id=964 Larry, I'm failing to see the extension on his 10er. Can you help please? Again it may not help me anyway, as I own a 520. Report
