BillyJack Posted January 8, 2020 Report Posted January 8, 2020 Needing belt and a 12" disc. Don't wanna go to KC. Any deals on line for singles of quality. Like klingspor,VSM or 3M...thx FlGatorwood 1 Quote
steven newman Posted January 8, 2020 Report Posted January 8, 2020 Harbor Freight....get the "Red" belts. FlGatorwood and Cal 2 Quote
Gerald Posted January 8, 2020 Report Posted January 8, 2020 Klingspor Woodworking Shop has 12 inch 100 grit disc pack of 5 PSA for 29.65 Cal and FlGatorwood 2 Quote
BillyJack Posted January 8, 2020 Author Report Posted January 8, 2020 2 hours ago, steven newman said: Harbor Freight....get the "Red" belts. They only had 4 different belt's none red,,, FlGatorwood, Gunny and Cal 3 Quote
BillyJack Posted January 8, 2020 Author Report Posted January 8, 2020 2 hours ago, Gerald said: Klingspor Woodworking Shop has 12 inch 100 grit disc pack of 5 PSA for 29.65 Thx I'll look into it. The shipping is the killer most times..thx FlGatorwood and Cal 2 Quote
lew Posted January 8, 2020 Report Posted January 8, 2020 Try these folks- https://www.supergrit.com/view.php?pg=index FlGatorwood and Cal 2 Quote
BillyJack Posted January 9, 2020 Author Report Posted January 9, 2020 Thanks for the replies. I have to have good belta for the edge sander for doors, radious, etc..but for the Delta sander I may try the Harbor Freight. It won't get used except on small stuff...thx Cal and FlGatorwood 2 Quote
Gunny Posted January 9, 2020 Report Posted January 9, 2020 20 hours ago, Gerald said: Klingspor Woodworking Shop has 12 inch 100 grit disc pack of 5 PSA for 29.65 Are they good? I have some that are off brand. They were free but they don't seem to last and tear easy. FlGatorwood and Cal 2 Quote
BillyJack Posted January 9, 2020 Author Report Posted January 9, 2020 I'm not much for a paper backed disc. Prefer clothed but if there out of my pocket and there not expensive I can live with it... The harbor freight are not far from me and if the bestscare ok , I'm ok... FlGatorwood and Cal 2 Quote
BillyJack Posted January 9, 2020 Author Report Posted January 9, 2020 The problem with Klingspor in KC they keep going through salesman and I lose my great price connection. The last guy said he had my sanding belts in his garage as he keep stock at home and some were out of date but we're still good. He's gone, now I'm out of connections... Gunny, FlGatorwood and Cal 1 2 Quote
BillyJack Posted January 10, 2020 Author Report Posted January 10, 2020 If it doesn't snow too bad I'm gonna go a little further out of my way to Harbor Freight. I'm gonna put a plug on the sander today to give it a trial run.. FlGatorwood 1 Quote
BillyJack Posted January 10, 2020 Author Report Posted January 10, 2020 I pulled the plug off my planer and installed it on the sander. Works fine. I think mineral spirits to clean it with might be ok. Gunny and FlGatorwood 2 Quote
BillyJack Posted January 13, 2020 Author Report Posted January 13, 2020 Tried the harbor freight 6x48 but is way too tight. Hard on the bearings. Looking for an adjustment but will have to look in the manual. If not the klingspor on it now works fine and will go that direction... FlGatorwood 1 Quote
BillyJack Posted January 17, 2020 Author Report Posted January 17, 2020 Anybody else have trouble with the harbor freight belt on a delta sander? I'm wondering if it's just a bad belt.....because they ship them flat when I go up there I will look for variations in length. Maybe I got a bad belt? FlGatorwood 1 Quote
lew Posted January 17, 2020 Report Posted January 17, 2020 Not that particular combo but I have an oscillating spindle sander (Taiwanese) that has the rubber inserts in metric diameters. Some of the sanding sleeves I have bought are a little too sung. FlGatorwood and Gunny 1 1 Quote
Gene Howe Posted January 18, 2020 Report Posted January 18, 2020 Hey @lew, can you find Imperial sized inserts? Maybe that sanding supply store near you? I modified my Rigid oscillator to accept longer sleeves but, I can't remember where I got the rubber inserts. FlGatorwood and Gunny 2 Quote
lew Posted January 18, 2020 Report Posted January 18, 2020 45 minutes ago, Gene Howe said: Hey @lew, can you find Imperial sized inserts? Maybe that sanding supply store near you? I modified my Rigid oscillator to accept longer sleeves but, I can't remember where I got the rubber inserts. I modified the rubber ones I had to fit. A little sanding and they fit FlGatorwood, Gunny and Gene Howe 3 Quote
BillyJack Posted February 4, 2020 Author Report Posted February 4, 2020 (edited) I've been over this sander a couple times. The only way to make the harbor freight belt work is to grind the two bars as there aren't springs to allow variables in belt sizes. Still haven't been back to harbor freight to check for variations in the sizing. I dont use the belt as I have an edge sander but do like the disc sander...laying flat the belt is 24" end to end. Edited February 4, 2020 by BillyJack Quote
BillyJack Posted February 4, 2020 Author Report Posted February 4, 2020 These two bars determine the height. Quote
