LarryS Posted December 6, 2019 Report Posted December 6, 2019 I'm making cabinet doors for my son. I have 3/16" plywood. Do you think making 1/4" dado joints are to wide. Should I consider the 1/16" for expansion? Or is that too much? I'm doing a mortise & tension joint on the corners. It would make it so much easier doing the 1/4". I try to get 1/4" plywood when I do my doors but all these odd size plywoods anymore. lew and Cal 2 Quote
lew Posted December 6, 2019 Report Posted December 6, 2019 1/4" might rattle. Plywood shouldn't expand and I doubt the stiles would change widths any significant amount. The 1/16" allowance might not be necessary. Just my 2¢ LarryS, Cal and Gunny 3 Quote
Gene Howe Posted December 6, 2019 Report Posted December 6, 2019 It'll probably rattle. You might considder some hollow screen spline. Ace has it that's .016 thick but, being hollow it should work. Gunny, Cal and LarryS 3 Quote
BillyJack Posted December 6, 2019 Report Posted December 6, 2019 You have to get two sided MDF in 1/4 to get the best fit.thrse days even its getting thinner. A lot of outfits going to the 3/16 cutters ...for that foreign crap.. Cal and LarryS 2 Quote
Gunny Posted December 7, 2019 Report Posted December 7, 2019 I would go 3/16" dado for match fit. As @lew and @Gene Howe stated it will rattle otherwise. Plywood remains stable so no worries about expansion. Several of the doors in my shop have 1/4 ish plywood and none have ever broken for that reason as do all the kitchen cabinet doors I made 20+ years ago. Now bashing them with a 10ft 2x4 because I wasn't paying attention, that was on me. 1fizgig, Cal and LarryS 2 1 Quote
LarryS Posted December 7, 2019 Author Report Posted December 7, 2019 Thank you everyone. I was getting ready to set up for the 3/16" and my son come over and said the 1/4" dado will be fine. He said he can put a little bit of silicone around the door to help with the little gap. By the way my son works for a glass company that makes their own metal frames for commercial doors and windows. I think he knows that we are working with wood not metal? When we get done with the cabinet doors they will be fine and look nice!! Cal and Gunny 2 Quote
JimM Posted December 7, 2019 Report Posted December 7, 2019 I had a similar issue a few months ago. In my area (central NY) the blue box stocks a full 1/4" maple plywood priced about $25. It worked great and much better to work with than MDF, IMO. Jim LarryS, Gunny and Cal 3 Quote
Cal Posted December 7, 2019 Report Posted December 7, 2019 I would likely use a regular saw blade and make two passes by adjusting the fence on the second pass to end up with a 3/16" dado. LarryS and Gunny 2 Quote
Gunny Posted December 7, 2019 Report Posted December 7, 2019 1 hour ago, Cal said: I would likely use a regular saw blade and make two passes by adjusting the fence on the second pass to end up with a 3/16" dado. Same here. LarryS 1 Quote
