July 19, 20188 yr comment_154621 Gotcha, at least for the moment. How large do the sheets need to be? 5", 6" wide? Report
July 19, 20188 yr comment_154623 Check out https://www.mcmaster.com/#hook-and-loop/=1ds7lbq They offer self-adhesive backed in 6" width x 5 ft long for ~$48 or 10' long for ~$76...not sure about shipping costs..choice of "designer colors" too. Report
July 19, 20188 yr comment_154628 28 minutes ago, Gene Howe said: Now worries Dave. Welcome to my world. And lately, I can't blame the sun. I'm wanting to just replace the worn out Velcro on the sanders. Not the whole pad. Are you using the Merca Mesh sanding discs? I found that they wear out the backing disc on the ROS sanders fast. I use a Merka H&L pad on my ROS between the ROS and the sanding disc, that way the ROS is protected. The best way is to have an ROS for each grit, makes for faster sanding too. Herb Report
July 19, 20188 yr Author comment_154631 16 minutes ago, Dadio said: Are you using the Merca Mesh sanding discs? I found that they wear out the backing disc on the ROS sanders fast. I use a Merka H&L pad on my ROS between the ROS and the sanding disc, that way the ROS is protected. The best way is to have an ROS for each grit, makes for faster sanding too. Herb No, haven't used Mirka mesh. I have a few rolls of their paper. It's good stuff. But, I only use it with sanding blocks or jitterbugs...which isn't often. Edited July 19, 20188 yr by Gene Howe Report
July 20, 20188 yr comment_154724 I'm wondering if you might be able to find velcro sheets at a fabric store. I'll talk to my wife when she gets home. Edited July 20, 20188 yr by It Was Al B Report
July 21, 20188 yr comment_154733 Velcro is available at stores like Michael's and Jo Ann fabrics. It may even be available at Walmart according to my wife. Report
July 21, 20188 yr Author comment_154739 Thanks, Al and, Mrs. Al. Closest Michael's or Joannes is over 100 mi. away. But, Wallyworld is in town. I'll see if I can find it on either of the three's we sites. Report
July 21, 20188 yr Author comment_154742 9 minutes ago, Stick486 said: had a look... found they only had tape and not sheets... Me too. Amazon has it in 5" wide rolls but onle "sew on". Might get a roll and try some 3M 77. Report
July 21, 20188 yr comment_154745 Not sheets but pretty reasonable prices- https://www.industrialabrasives.com/hook-loop-discs-sheets-psa-hook-adaptors-c-201_176.html This is my goto place for any sanding need http://www.supergrit.com/products/products_accessories-conversion Report
July 21, 20188 yr Author comment_154747 @lew, many thanks. Supergrit it is. IIRC, they're just down the road from you, right? Report
