April 6, 20188 yr comment_145847 I got to work on my mini tailstock slippage. I went to our local farm store where they have larger washers than hardware stores. As you can see from the pictures of the pictures, small is original one piece, large is my assembly of 4 washers (42 cents) held together with JB weld. I had to do a small amount of filing to get a nice fit. I did some testing and it holds good. The clamping surface has probably doubled. The question is.........will JB weld hold. I was going to solder them and may have to if JB fails Edited April 6, 20188 yr by Ron Altier added 42 cents Report
April 6, 20188 yr comment_145850 My guess is that the JB Weld will do the trick as the pressure should be squeezing the washers together. Report
April 6, 20188 yr comment_145856 It might hold because the smaller washers don't carry any load. They are there just to keeps the disk centered between the ways. Report
April 6, 20188 yr Author comment_145859 That's what I was thinking too. I did try it and it works well. Only time and projects will tell Report
