Popular Post Cliff Posted March 12, 2018 Popular Post Report Posted March 12, 2018 some gozillion years ago I was given a twin state Sgt Welsh rotary vein vacuum pump that fell of a truck. No really it fell off the truck & got damaged ( just the belt shroud) but there was an insurance claim and this one was unclaimed so the shipper gave it to me. And a decade or so later I'm finally trying to put it to use. I got a small air tank and welded bungs to it so I can run 1" piping to it. It is the vacuum reservoir in case of power failure. Then mounted it and the pump together around a corner on the other side of a wall and ran 1" copper to the lathe with a parker needle valve and a vacuum gauge and LOOKY MA I can hold a great vacuum and even lower the hold to what ever HG I want with the needle valve . AND When I shut it off it holds the vacuum for a good long time. The reason for the large piping is over a long run ya gotta have a big pipe a small one just doesn't work well HARO50, p_toad, Gerald and 4 others 7 Quote
HandyDan Posted March 12, 2018 Report Posted March 12, 2018 12 minutes ago, Cliff said: The reason for the large piping is over a long run ya gotta have a big pipe a small one just doesn't work well Gives more volume too. Just like air pressure more volume never hurts. I like the you set-up. Quote
Steve Krumanaker Posted March 12, 2018 Report Posted March 12, 2018 Looks like a nice set up. What is your intended use? A vacuum chuck for your lathe? Steve Quote
lew Posted March 12, 2018 Report Posted March 12, 2018 Cool! Are you still using the generator? I see there's another bit of snow headed your way. Quote
Grandpadave52 Posted March 13, 2018 Report Posted March 13, 2018 (edited) Nice work Cliff...pretty good pump to pull & hold 27" especially for the price you gave. Edited March 13, 2018 by Grandpadave52 HARO50 1 Quote
Fred W. Hargis Jr Posted March 13, 2018 Report Posted March 13, 2018 Well done. Like Steve asked: what's the intended use? Quote
Cliff Posted March 13, 2018 Author Report Posted March 13, 2018 10 hours ago, Fred W. Hargis Jr said: Well done. Like Steve asked: what's the intended use? to hold things on the lathe and any other vacuum need in the shop like laminating. Quote
Cliff Posted March 13, 2018 Author Report Posted March 13, 2018 I rather like my vacuum coupling. It's an industrial bit o' kit I got for next to nuthin' on the flea bay. I can go pretty fast - - not mind you that I'd trust vacuum with high RPMs. I welded up a rig to go on the coupling to prevent it from spinning. Apparently it is overkill and unnecessary because the hose is stiff enough to keep it still the_pump_vid.mp4 vacuum_at_1241_RPM.mp4 HARO50, p_toad, DuckSoup and 1 other 4 Quote
Cliff Posted March 14, 2018 Author Report Posted March 14, 2018 1 hour ago, lew said: Looks like a mighty fine setup to me. Thanks, Imagine my surprise when my bung welding held vacuum. lew and HARO50 1 1 Quote
HandyDan Posted March 14, 2018 Report Posted March 14, 2018 Nice Cliff. Love the tank. Don't see that in too many set ups. Quote
Popular Post Cliff Posted March 14, 2018 Author Popular Post Report Posted March 14, 2018 (edited) well looky a bowl gosh darn the blasted thing works. Ya know multiply those 15 pounds per sq inch really add up to substantial force~!!! I played with pulling that sucker off all through the pressure range and it was unmovable without destroying the bowl way down to a lousy five inches of mercury. I think I'll like this gizmo AND THERE's a VIDEO but when up load them they only show as a link. bowl on vac chuck-01.mp4 Edited March 14, 2018 by Cliff HARO50, Grandpadave52, Dadio and 2 others 5 Quote
Cliff Posted March 14, 2018 Author Report Posted March 14, 2018 (edited) here is a vid of the coupling I took the fixture off that I had on it. the hose seems plenty stiff enough to hold it under power The pipe thread into that aluminum disk is a left hand thread. Hard to find a left hand pipe tap. If you need one I got one you can borrow so long as it won't be used in steel. I turned the aluminum disk so that it's double as a pulley for my slow speed rig. vacuum coupling.mp4 Edited March 14, 2018 by Cliff Grandpadave52 1 Quote
Cliff Posted March 15, 2018 Author Report Posted March 15, 2018 the coupling There are plenty for cheap sold as rotary unions https://photos.smugmug.com/Tools-I-made-or-Purchased/i-HgWhLPB/0/c69641d8/1920/vacuum coupling-1920.mp4 Dadio 1 Quote
Steve Krumanaker Posted March 15, 2018 Report Posted March 15, 2018 This is a good thread and I'm glad you shared it, have you got a link to buy those unions? Steve Quote
Cliff Posted March 17, 2018 Author Report Posted March 17, 2018 On 3/15/2018 at 4:16 PM, Steve Krumanaker said: shared it, have you got a link to buy those unions? I got it on the flea bay https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR2.TRC0.A0.H0.Xrotary+union.TRS1&_nkw=rotary+union&_sacat=0 lew and Steve Krumanaker 2 Quote
Steve Krumanaker Posted March 17, 2018 Report Posted March 17, 2018 48 minutes ago, Cliff said: I got it on the flea bay https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR2.TRC0.A0.H0.Xrotary+union.TRS1&_nkw=rotary+union&_sacat=0 Thank you sir!! Quote
