Showing results for tags 'tool tray'.
so, back to the Dungeon Shop I go. Have a nice stash of chisels, nothing real fancy, but they need a better home. Already have a spot for the router bits but I don't think it would work to hold chisels. Grabbed a pine board that was long enough to go in the Tool Chest as a tray. It was a might wide so I ripped it down the middle with the old Craftsman circular saw. There are just some things I will not do by hand, and ripping long boards with a handsaw is one of them. Got the two halves into the vise, to take care of any dippity-dos I did both edges, too. That Wards #78 was next. Needed a rebate to house the bottom of the tray. Photo is a might fuzzy( again) but There IS a rebate there. The wood was so smooth, it shone like a beacon. Then, hand sawed for some dados. needed one on each end, and one in the middle. I was going to rebate the bottom of the dividers, but the fights were starting. So, made the floor board the full length, instead. One dado was in some knotty grain, and broke out, screws for that end. Trial fits as i go I WILL get YELLED at for having my "junk" on HER washer. The floor boards are two pieces. The old sycamore one there wasn't quite long enough, and had a bow at one end. Had a thin piece of QSWO available, just a might wide, and too long. Saw the end off, and used a jointer to get to the right width. Did find out something strange about this old oak It makes little curly things, instead of long shavings. I did get the floor for the tray ready for a test fit Just some screws, nails and glue. then come the fun parts, getting a way to set all them chisels in the tray. That will be...next time. Stay tuned.
have a pile of auger bits laying around, getting beat up. Got to do something about that. Had a 2x4 of pine. Planed until squared up. laid out a center line between the two knot infested areas. Chucked up the largest bit in to a 10" brace. Turned out to be a might small, but i drilled a hole anyway. Kept changing out for the next size smaller, until a tiny #4 was used. A #4 is 4/16" in diameter. largest was a 20. There was even an expansion bit, not a very good one, but it worked. Yeah, yeah, a bit of a blowout on the big one. Most are as deep as I could get them. Might chase the holes with the Forstner bits, to make pulling then out easier. You see,they sit like this lovely sight, ain't it? anyway, I'm building a tray-like contraption to hold this strange looking thingy A bit of Barn Siding stuff, the 2x4 rack, and a plywood filler. Plan right now is to make the rack pivot like any other Drill Index. Then lay back down into the tray. Might get two pivot pins, might be two hinges. Won't be some fancy-schmanzy dovetailed tray, either. Have a whole series of trays planned. Lots of files and rasps to find a home for, lots of screwdrivers, pliers, wrenches, and other doo-dads. Might even make something to house these clowns, too All Jack planes. 5 #5s in the middle, a 5-1/2 on the left end, a 5-1/4 SW on the right end. Might have enough of these? Then, there are a few drills Two of the three braces, and an eggbeater. Getting a might crowded down here?
