Showing results for tags 'rollin pin'.
Well, last Wednesday in September. Hasn't been a great week, maybe a new month will chase away Mr. Murphy. Our Patriot Turners- @Gerald had some misfortune while turning a hollow form- He was looking for some suggestions on how to have the repair enhance the turning. Check out his post and see if you can offer any ideas- @bradleyheathhays is looking for suggestions on which type of bowl scraper to buy. Several of our turners added their thoughts; what are yours @Masonsailor turned some items for his reloading area. He shows us more of what he did in this post- A week or so ago @Gerald posted about a jam chuck. We are still getting input and inquiries about the chuck. If you made that chuck, please add your input to the conversation- I made a post asking for recommendations on air filtration masks. I really appreciate the input. I haven't decided on the route I want to take. I subscribe to the Alton Brown philosophy that every item should be a multitasker but they should also do those things well. If you have any ideas to add to the already suggested items, I would appreciate it- What’s Coming Up- Click on the images for links to registration and more information- For The Newbies- Mike Waldt works on that ash bowls. This is a live demonstration with questions and lots of good tips- Expand Your Horizons- If you are considering learning to cut threads, Mike Peace demonstrates a few tricks for setting up a thread cutting jig- New Turning Items- The Woodturning Tool Store has the NEW Elio-DR Safe Drive- See more at- https://woodturningtoolstore.com/product/elio-dr-safe-drive-2/?receiptful=614cfd7b710e56003dbee782&utm_source=CM Commerce&utm_medium=email&utm_campaign=newsletter-121&utm_term=newsletter&utm_content=other&receiptfultype=newsletter Everything Else- Rick Turns list of YouTube woodturning videos from last week- Been fighting computer problems for the past several days so shop time has been non-existent. Before everything went south, I did manage to get the last batch of rolling pins shaped but not sanded- probably a good thing as I am still hawking up lugies and haven't gotten better dust protection. After the rolling pins are pretty much round and dimensioned, the tapering jig is used to shape them. I used to do this free hand but getting consistent results proved difficult. The base of the jig holds the taper guide at the bottom/back. The cutting is done with a handheld, sliding fixture that houses the HHS cutter and an adjustable follower (bolt). The cutter is removable for sharpening. I'm using a 5/16" square tool stock now. It seems to make a better cut that the 1/4" square cutter I use originally. Cutter and follower bolt- Cutter closeup- After the overall shaping is finished, The tapering jig is removed. Each end of the pin gets the shoulders rounded. I use either a small spindle gouge or the Easy Wood Tools rougher with an R2 cutter. The pins are now ready for sanding. Safe turning and stay well
