Showing results for tags 'rip cuts'.
and very little got done. Brought two 1 x 10 pine boards to the shop, since they were stored against the wall of the house. Cut them to a length needed. Ripped one right down the middle. Ripped just over 5" out of the second board. Used a jointah plane to ease an edge or two And the chest now has a bottom. Screwed to the cleats along the outside edges. Center plank is just held by a pair of screws, one on each end. Had the box clamped to the bench for a little clean up Well I used this to clean up after a belt sander leveled things a bit. Then a block plane for some detail work.....Then set up a drill press with a special bit Cuts a tapered plug. Chunk of scrap wood is Black Walnut. I used a screwdriver tip to pop the plugs out.A littlte glue into the counter bore, and bang a plug home. Later, after the glue has set for awhile, a block plane to trim these down Lets see, seven to a corner, and there are four such corners,, might take a bit. BTW: Beltsander don't work very well trimming the plugs down. Gouges the wood, and burns the plug. Just about any sharp plane will do. Stay tuned....
- 6 replies
- black walnut
- belt sander
(and 4 more)
