Showing results for tags 'rebecca degroot'.
	More rain to fill the PA potholes Our Patriot Turners- @Fred W. Hargis Jr is making progress on his coin displays. He is turning the pedestals for each coin and ran into a little problem and asked our advice. Check out Fred's post for our members suggestions. I finally dug out the chainsaw and went for some sycamore. Cut everything on site instead of manhandling big chunks of logs. A bunch of approximately 6 x 6 pieces and some a little bigger. Ends sealed with old Titebond glue. Seven of these pieces have been rough turned, 4 soaked and in the drying box and 3 more in the soak now. I was surprised how much the log had spalted since the last time I cut from it, especially since it was not in contact with the ground. What’s Coming Up- If you missed Cindy Drozda's tool talk with Emma Cook, it is available on YouTube- For The Newbies- From Tomislav Tomasic on the importance of tool rest positioning- Expand Your Horizons- No Longworth chuck, no Cole Jaws? No problem! Sam Angelo demonstrates how to finish off the bottom of a bowl without those special chucks. Spindles, bowls, hollowing-- been there, done that?? But have you turned a Jelly Fish?? Carl Jacobson shows us this turned art work- Turning Time With Easy Wood Tools- Easy Wood Tools has a great selection of accessories for holding pieces on the lathe. For the headstock, besides their awesome Easy Chuck, they have faceplates, faceplate rings and drive centers. Faceplates- Faceplates are available for lathes with headstock spindles threads of 1 x 8, 1.25 x 8, M30 x 3.5 and M33 x 3.5. With diameters ranging from 2" to 4.5". The faceplates have a large number of holes to ensure secure mounting even on rough surfaces. Faceplate rings- The faceplate rings are machined from cold rolled steel. These heavy rings will work with most 4 jaw chucks. These are available in 3, 4.5 and 6 inch diameters. As with the EWT faceplates, the large number of holes provides secure mounting on uneven surfaces. With faceplate rings, there is no need to replace the chuck with a faceplate. Drive Centers- Being able to mount spindle work without removing your chuck can save time. EWT offers two styles of chuck mounted drive centers. 4 Prong- This heavy duty center offers a retracting point for easy centering and will work with most chucks. Multi-Spur As with the 4 prong drive center, the retracting point makes for easy centering and will fit most chucks. EWT hasn't ignored the tailstock either. Live Center- Standard #2 Morris taper with a 3/4 x 10 threaded nose for additional adapters. The center point position is adjustable. Stabilization Cones- Available in 1.5" and 4" diameter with 3/4 x 10 threads Some of these items are demonstrated and reviewed by Carl Jacobson- Another well known woodturner demonstrating EWT tools- Upcoming EWT live demonstration- Be sure to check you local Woodcraft store for additional live EWT demos during the month of June. @Jordan Martindale New Turning Items- Everything Else- From Ron Brown's newsletter Opportunity "There is little opportunity when nothing changes...but with change comes opportunity." My daughter is brilliant! As a scientist working in a large laboratory developing poultry vaccines, change was constant: personnel, protocols, facilities, and equipment. It bothered her every time. My counsel was always to welcome changes because there is little opportunity when nothing changes. But with change, opportunity always comes, and it always did. For the hobby woodturner, this speaks to stagnation. If your techniques remain the same, your projects look the same, and your understanding of wood and tools doesn't evolve, your opportunities for growth and enjoyment are limited. You might become proficient at a few specific tasks, but you'll likely hit a plateau. • Limited Skill Development • Repetitive Projects • Missed Learning • Lack of Innovation "...but with change comes opportunity." This is the exciting part! Change, even when it feels a little daunting, opens doors to new possibilities and growth in your woodturning journey. • Learning New Skills: Experimenting with different wood species or mastering a new finishing technique (like CA), expands your capabilities and opens up new project possibilities. • Exploring Different Project Types: Moving beyond simple bowls to tackle complex spindle projects, or even furniture components, can lead to greater satisfaction. • Adopting New Tools: Investing in a new tool, jig, or fixture, even a seemingly small one, can revolutionize your workflow and the types of projects you can undertake. • Discovering New Materials: Experimenting with epoxy resin, metal inlays, or even incorporating non-traditional materials into your woodworking can lead to unique and exciting results. • Sharing and Learning from Others: Engaging with the woodturning community online or in person exposes you to different approaches, ideas, and critiques, fostering growth and new opportunities for learning. Other key precepts to consider: • Master New Forms: Progressing beyond basic shapes to complex forms (hollow vessels, segmented/off-center turning) provides significant skill development. • Experiment with Different Woods: Exploring various wood types (hardwoods, softwoods, figured, green) reveals diverse textures, colors, and challenges. • Learn New Tool Techniques: Utilizing different gouge profiles, scrapers, and specialized tools expands achievable effects and forms. • Explore Embellishments: Incorporating carving, burning, painting, or resin inlays adds artistic dimensions to turned pieces. • Improve Sharpening Skills and Techniques: Continuously refining tool sharpening and lathe stance improves cut quality, control, and intricacy. • Embrace New Technologies: Integrating modern technologies like laser engravers and advanced finishes offers new creative possibilities in woodturning. Don't be afraid to step outside your comfort zone at the lathe. Embrace the challenges that come with learning new techniques, experimenting with different materials, and exploring new forms. Each change, each new skill acquired, each different wood you turn, is an opportunity to grow as a craftsman, to create more unique and satisfying pieces, and to deepen your enjoyment of this excellent craft. Safe turning
	I swear one of these days I'm going to use my lathe and turn something. Our Patriot Turners- Thanks to @User74 for posting his cool lidded bowl, on our "Off the Lathe" topic! More images and a description of how he did the dark ring embellishment starts here- @Fred W. Hargis Jr asked our turners their thoughts on a vacuum chuck vs. a jam chuck. Fred received some great input. Please check out his post and see if you can add to the discussion- @RustyFN posted his "basket weave" vase. This amazing piece certainly take a whole lot of patience, a steady hand and perfect eye sight! See Rusty's post for more description and process images- What’s Coming Up- If you missed Cindy Drozda's Tool Talk last week, she uploaded the event to her YouTube page for viewing. This Saturday- April 5- is the free, online Vendors Showcase. Registration can be done at - https://streamyard.com/watch/UwJbzWJMHmsV?receiptful=67eadc4126171910e58cc7c7&utm_source=CM Commerce&utm_medium=email&utm_campaign=newsletter-445&utm_term=newsletter&utm_content=other&receiptfultype=newsletter Or- https://streamyard.com/watch/UwJbzWJMHmsV For The Newbies- Mike Peace posted a 5 year review the Record Power Coronet Herald lathe. It is a mid size variable speed wood lathe with a 14” swing and a 1HP motor. If you are thinking of upgrading, check out what he has to say. Expand Your Horizons- The first of the month brings another turning collaboration between Richard Raffan, Sam Angelo, Tomislav Tomasic and Mike Peace. As you saw in Cindy's tool talk, Easter is approaching and turning eggs is as much fun as coloring real ones- except they are not as edible. Tim Yoder goes one step farther and turns an "Easter ??? Bunny". Some of you may be aware of my love of Monty Python- Turning Time With Easy Wood Tools- Easy Wood Tool Demonstrations for the month of April for locations around the country- Why does Easy Wood Tools have the best carbide in the industry? Check out this article- Not All Carbide is Created Equal Final.pdf Tim Yoder turns Easter Eggs using Easy Wood Tools- @Jordan Martindale New Turning Items- Hoping the Spring Vendors Showcase will be introducing some new stuff. Check out the link above. Everything Else- Many turners are familiar with the name Rebecca DeGroot. Well known as a talented turner with a weird imagination, a tattoo artist, former high school art instructor and a contestant on the Food Network's Outrageous Pumpkins. Ms. DeGroot is featured in the February American Woodturner magazine. Link to the article- https://www.woodturner.org/Woodturner/Resources/AmericanWoodturner/2025/40-1/Rebecca-DeGroots-Creepy-Crawlers.aspx?fbclid=IwY2xjawJap6RleHRuA2FlbQIxMAABHYoPblEISEOS8K8BmeTWgGCyC-EDP0Vs5r4eq28xnALVQzulxIePbROvyA_aem_sfboYCYcwKY5SwZV6VzkVg Safe turning
	December 7th, never forget the sacrifices- We have made it past the half way point in donations for our Ward 57 Christmas project. If you haven't gotten around to donating, please don't wait! We are purchasing gifts for the family and need the funds to fulfill their requests. Jump over here and make that donation! Our Patriot Turners- We've had lots going on this past week. Some turnings, some questions and even an Internet appearance by one of out own! @forty_caliber posted a bowl he made from the log he questioned the origin, last week. Everyone seemed to come to a consensus about the species See what everyone said about this turning and check the additional images- @RustyFN showed us a gorgeous, turned, flat sided vessel. He told us he had wanted to make one for quite some time. Everyone had lots of positive comments. More images and the dimensions are in Rusty's post- @StaticLV2 added to a previous thread on turning center finders. His is a quick shop made device- An explanation and more action shots are here- Static also posed a question about duplicating a turning. To freehand multiple copies and have them be identical isn't easy. Here's what he is working on- And these are his thoughts- Yesterday, Cindy Drozda held one of her Zoom show and tell get togethers. Our own @Gerald presented his copper rimmed platter and his "poke-a-dot" platter. Gerald has shared both those turnings with us in the past. Cindy usually posts those Zoom talks on her YouTube channel. Not there yet but keep checking to catch our Star in action!! What’s Coming Up- Click on the images for links to more information and registration- @forty_caliber gave us a heads up on this. For The Newbies- @HandyDan posted this to show the versatility of the spindle gouge. This artist proves you don't need a dozen tools to create some beautiful pieces Another entry into the gnome turning. This one is from Craft Supplies USA- Expand Your Horizons- Richard Raffan turns a cross grain green ash spatula pot- New Turning Items- Found another source for those threaded rings. These are brass. The ones from Ruth Niles are bronze and are advertised specifically for urns. https://spiracraft.com/product/threaded-brass-rings-for-vessels/?inf_contact_key=a4e1cb7d17423b01ff886ccc58b30487 These are called "Ron's Pearls". Bits of wisdom put together by Ron Brown and are free to download. Get your copy at- https://www.ronbrownsbest.com/index.php?route=product/product&path=4&product_id=927 Everything Else- Rick Turns list of YouTube woodturning videos from last week- Safe turning
- 5 replies
		- rick turns
- ron brown
- (and 20 more)
                    .png.e9bd676dce13e4a5b2ebe866bb74a637.png)
                    .jpeg.cf178f43eec83ac16c81fb74e61ce077.jpeg.eb63a1a4641ababfc14bea24ad21e13d.jpeg)
                    .png.13be55e9d3f2a49c33fdc049bb1b8485.png)
                    RebeccaDeGroot_Facebook.png.af27348f3e19766fd5c77e39eb8a1cd0.png)
