Showing results for tags 'put away'.
Ok, latest Project is about ...done. Time to clean up the bench, put away the toys,,,and maybe rehab a few items.. I can finally set this back on the bench....bench is a bit ...full... Over flow from the Tool Well? "Name that Tool"? How do you hang this thing up.... Every shop could use a 4-in-hand rasp/file....but it needs a place to sit, until called for.. Chisel shaped objects, at least the 3 in front...the other was rehabbed long ago...clean, sharpen, and re-do them handles.. May "refine" the other two....Scratch Awls were also cleaned, sharpened up, and a coat of finish brushed on... The rasp was cleaned of rust and crud, pocket knife was too..and sharpened... Anyone want to stop by and help out? Stay tuned..( may build a second row to the back of the bench storage rack....may need 2..?)
Time to put the tool away... In the case of the old Stanley #45, means tear down, clean the parts.. Get the case down off the shelf, open it up on the bench... Kind of empty? Short rods, slitter, cove cutter, match cutter (3/16") spares parts, 2 screwdrivers..bunch of cutters.... Cam rest, 2 long rods, fence, sliding stock,,there are 2 spare spurs in there, and a bolt for one. Leaves just enough room, to lay the main stock in there. Plane is from Roxton Pond, Que. , CAN. and has the SW logo...mid 1920s model, type 20. Close the lid.. And back onto the shelf it goes...for now.
