Showing results for tags 'push sticks'.
Mother Nature decided to treat us with two days of summer. Got a lot of yard work done. Our Patriot Turners- @Headhunter showed us some of his early work. Like a lot of turners, he started out with some pens. He wondered if any of our turners started that way- @forty_caliber posted some images of a platter he turned. I wasn't familiar with his term for the species. Well, Google is your friend and discovered another name for it Check out his post for more images. Oh yeah- it's Osage Orange. Forty also posted a beautiful bowl. I really love the colors and contrasts in this one- Check out how he did this! Our thread of "What's On Your Lathe" continues to be quite popular. This is about where we left off last week- What’s Coming Up- Click on the images for links to more information and registration. If you missed it live, Cindy Drozda put her presentation of "Planning A Turned Box" on her YouTube channel. The beauty of her turnings don't just happen by accident! For The Newbies- A neat little spring turning for Easter- The bandsaw is quite possibly the next most used piece of equipment, besides the lathe, for a turner. Mike Peace demonstrates some of the push sticks that can be used when cutting- Expand Your Horizons- Something I've always struggled with is pricing a turning. Kent Weakley has some guidance for turned bowls- Every turner seems to have their own procedure for turning an object. This is the second in the series of "4 Ways" where four turners do the same project, using their own techniques. Tim Yoder turns an arched, winged bowl. Not sure what kept the lathe from taking off and flying around his shop! Richard Raffan turns and burns a natural edge bowl. What I found interesting is that he does the entire bowl without the aid of a faceplate, Cole jaws or jam chuck- New Turning Items- With all of the "burning" as embellishment, this might be something interesting- Everything Else- Playing with some of the elm from behind the shed, This piece was rough turned and then soaked for 3 days in a soap/water solution. Looks pretty ugly but as it dries the color will lighten and turning to the final thickness will remove all discolorations from the soak. These go into my little drying box ala Rick Turns. I weigh the pieces once each day until they reach equilibrium. The day after I put this one in, it lost 100 grams of weight. Safe turning
- 4 replies
- tim yoder
- tomislav tomisec
- (and 20 more)
About a week or so ago I was ripping a 2X4 block into a 1X2 on the table saw and was using a plastic pusher stick that came with my Bosch table saw. I really like the feel of the pusher stick as it is heavy and fits my hand. Apparently as the block was leaving the saw blade, I angled the pusher to keep it tight against the fence and the blade caught the push stick. The pusher exploded in my hand, putting a gash in my palm that required 7 stitches. The fact I am on blood thinners didn't help the situation either. It wasn't squirting ,just seeping and soaking. Later upon examining the pusher stick it looks like my assumption was right in having twisted the pusher into the blade. The block didn't kick back and showed no sign of the mishap. It looked like the blade melted the plastic and welded to it for a second by the cut in the pusher. I wonder if a wooden pusher would have faired better? I am certain a wooden one would not have exploded. Here are some pictures to give you an idea of what I am talking about. Herb
- 41 replies
- push sticks
- safety
(and 2 more)
Just watched this video and thought the push stick works well. Keep you fingers well away from the blade, has ample gripping and can still apply pressure toward the fence.
ANGEL OF HANDSAW GRIP/HAND HOLT, I COPIED ON 1/2"PLY. THIS PLY IS 18" LONG X 6" W. FITTED A RUNNER ON BOTTOM = GROVE, PLY FITS DOWN IN.=1" WIDE. AT HAND HOLT END OF RUNNER IS A HEEL BOUT 3/16 PROUD OF REMAINDER OF RUNNER(HEEL IS WHAT PUSHES MATERIAL TO/PAST TS BLADE). NOW OTHER END OF RUNNER GLUE STRIP OF SAND PAPER, HELPS HOLD RUNNER IN PLACE ON TOP OF PIECE BEING PUSHED. PURPOSE::KEEP YOUR HAND ABOVE BLADE, HAVING CONTROL OF WORK PIECE. YEAW, I HAVE A SMALLER ONE FOR PUSHING THRU THIN CUTS.
