Showing results for tags 'pinyon pine'.
The Tree The Pinyon Pine (pronounced Pin-yone) is the nut tree of the Southwest. It clings to canyon sides and mountain slopes at elevations from 5,000 to 9,000 feet. It is a hardy hard scraggy pine and is one of the four nut pines in the southwest states. It is a small un-shapely tree 15 to 50 feet tall and 12 to 80 inches in diameter. The sharp pointed needles are a dark yellowish green and grow in pairs. The egg-shaped cones form on the ends of the branches. They are a shiny yellowish brown from one to two inches long, each bearing from 2 to 80 large reddish mottled brown seed-nuts. These nuts, which are about the size of a small navy bean, are the largest of the pine nuts and are edible and delicious. The Indians and Mexicans relish them particularly, and they have had a commercial demand as a nut delicacy. The nuts are usually baked soon after being gathered so as to retain their rich flavor. Pinyon Pine cones Pinyon Pine bark Pinyon Pine Common Names in Use Pinyon (Tex., Colo.) Pinon Pine (Colo.) New Mexican Pinon (lit) Pitch Pine (Utah.) Nut Pine (Tex., Colo.) Scrub Pine (Colo.) Growth Range The growth range of Pinyon Pine extends from southwestern Wyoming southward through Utah, Arizona, Colorado, New Mexico into northern Mexico, and southwestern Texas. Usually this tree is found in open stands and scattered groves along mountain slopes and canyon sides at elevations of from 5000 to 8000 feet. The Wood The wood is moderately soft, with resin ducts well scattered, appearing as tiny specks. The heartwood is a pale creamy brown-tan frequently with a slight reddish tinge while the sap-wood is relatively wide and somewhat lighter in color. Because of the many limbs it is usually knotty, is a little cross-grained and does not split easily. It is not easily nailed, but holds nails and screws well. When properly seasoned the wood stays in place well and shrinks very little. Pinyon Pine Lumber Uses This pine is used locally in Utah, Arizona, Colorado and New Mexico for fence posts, telephone poles, mine logging, charcoal and general construction. It is different in texture from other yellow pines with which it is sometimes confused. Bibliography Shelley E. Schoonover (American Woods) 1951 (Watling & Co. ) Santa Monica, CA
- pinyon pine
- pine
(and 2 more)
From the album: Pinyon Pine
Pinyon Pine tree. -
- pinus
- pinyon pine
(and 1 more)
- pinyon pine
- tree bark
(and 3 more)
- pinyon pine
- pine
(and 2 more)
