Showing results for tags 'frame & panel'.
Still had a stash of resaws to use up...or burn....prefer to use up, so.. And... Figure I could just glue these up into book-matched panels...for a Frame & Panel box/chest? Clamps and cauls.... Bench vise as a 3rd hand, and as a pair of cauls.. More clamps and cauls..might use this one for and end panel..means I need one for the other end Not too sure about that knot, yet.. let these sit a day...then remove the clamps..and nothing flies apart... The 2 longer panels, will have to trim these down to match each other...as for the other 2.. Need to trim all of these down.. To get rid of that knot, for one thing.. Set the rip fence to ~5" width...ran the best of each panel through...set aside the 3" cut-offs for later... Lengths...ends are 6" long, and the 2 sides are ~9" long.. Then try to plane the glue joints until they disappear.. Almost gone? Also needed to get them all FLAT.. A little more off of the right edge? repeat 3 more times.. Plane is a Stanley No.3, Type 11....as it was still out on the bench... Upstairs, there are 2 planks...one has a live edge...7/8" x 6 x 65-1/2" The other is a bit plain..and a foot shorter I figure I can cut the best section out...for a lid....maybe do a glue-up? Rest of the plank will get ripped down into parts for the frames. Some of which might get a bit "showy"? Spalted Maple? set the fence for 1-1/2" width..run a few strips to start up with.. Might be enough..we'll see... Next time? More rips...a LOT of cross cuts (16 parts !) and more rips...then see about grooves, tenons... Stay tuned..
- 35 replies
- frame & panel
- box
(and 1 more)
From the album: Pine Chester Drawers
a view of that troublesome side. Turned out, the plywood was primered! -
before the stain, showing the corner details, lots of cove molding going on, flat panel Frame & Panel sides -
From the album: Blanket Chest in Maple
Front of the blanket chest.- 1 comment
- maple
- frame & panel
(and 1 more)
A look at the front corner. Showing one of the ends. All the raised panels were glue-ups, and then "raised" using a handplane..or two. Foot details, side parts were chiseled to match the profile of the front of the foot. Rail between the feet has been rounded over, using a spokeshave.-
- corner views
- frame & panel
(and 1 more)
From the album: Maple Chest of Drawers
Side view, showing the hand plane made raised panels, sitting in the maple framed sides
