Showing results for tags 'dewalt 733'.
I have a Dewalt 733 surface planer that needs two rollers. I don't see any available. Wondering if there are any options for substitute or possibly a rebuild
- 4 replies
- dewalt 733
- planer
(and 1 more)
I bought the Dewalt 733 planer seems like in 2000 and at the time I thought how I should take care of it... And my answer to a post the other day was completely wrong for I have never applied any kind of slickum to the base or table where the wood lays while the rollers are pulling the wood through the blades, never. The reasoning back then and still now.... A person should plane both sides of a board and try to take off the same amount of wood from each side. So the board gets flipped back and forth swapping sides until the ruffness and thickness is achieved.... Each time a person flips the board over to plane the other side if he has applied wax to the table the rollers will be getting some of that wax each time the board is flipped.....and soon , in my thinking the rollers will collect enough wax to make them too slick to pull the wood........ All these years all I do is keep the table clean with soap and water.....and make sure the soap is removed completely for that will help rust form.....The Johnsons Paste Wax I do use on the threaded rods and that is the only place. Good or bad idea thats for you to decide but so far I have never had any trouble with the 733. I am on my sixth set of blades and I do have a machine especially to sharpen the planer blades but I decided long ago a new set of blades are easier for me than to set the machine up each time and hope for the best... And for those who are new to using a planer and wonder why a person should take off the same amount of wood from each side you can do an experiment... Take a good flat board , kiln dried, and take off say an 1/8" off of one side only, not all at once but a very small amount each pass, and lay it back somewhere for a few days and see what happens. Most all the time that board will warp something terrible... And most of the time it is not fixable.
- 9 replies
- dewalt 733
- planer
(and 1 more)
