Showing results for tags 'cardboard and plasti'.
  1. Ron Altier
    Redesigned vac
    Lew wrote about redesigning his lathe vac system. I was already tossing it around in my mind and wrote about a header, etc. Then it hit me, why go thru all that. I used thick cardboard and sheets of plastic. The thicker plastic came from the Dollar 3 for a dollar and are about 11" by 14". It cuts easily and can be taped to make larger sheets. I made alterations as I went. I installed my shop vac 2 and half inch hose in the lower left and formed the bendable plastic to fit. This prototype has worked really good so far. I also have in mind a divider made of the same plastic that can be moved to shorten or lengthen the coverage area for more effective pick up. I like it so well, I may just go ahead and use it as is. If not, a permanent set up will be much easier using what I have for plans. I used hot melt glue and clear packing tape to make it and things went fast. I altered as I went.
