Showing results for tags 'ash box'.
When last seen, these were what was left of the stash of Ash.. Not enough wide stuff, too many narrow things...sort through this and see what I can make.. Trim these, and maybe build a pair of doors? Try and have these 2 as the ends? Thin panel is too thin...the other? maybe rip down the center line, and make the 2 sides from them? Hmmmm...ok...Had Laundry Detail, today.... So...while I was down there....work on a few items...like the rough edges of the door parts.. Millers Falls No. 11, Type 2...works nicely as a jointer on small stuff...THEN trim for length, with the jointed edges against the mitre gauge.. Spread some glue along the mated edges, add some clamps and cauls... Door #1 is glued up...repeat for door #2. Then set both aside, for a day... While I work on a few other items ( waiting on the rinse cycle?) Saw was busy, today.... Wide panel has been ripped, the 2 end pieces were then ripped to match....was having trouble with one end piece...could not get it flat....and was getting too thin to work out..scrapped that one...need to resaw a new one......set up the tablesaw to cut a kerf...so that one side would match the existing sides/end Something like this..only, the saw blade can't reach all the way to the middle...we have ways... Saw about 1/2 way down, turn over, and saw from the other end.. Hardest part was keeping the saw from hitting the top of the vise... Needed to match this for thickness..came close...then cut away the worst parts, and match up to that other end piece... Wasn't quite flat,, We have ways.. Edges were a tad rough, too...saw marks.. Not a problem..planes were busy, today.. Ya think? Until the doors or done, this is about as far as I can go...need to size the box to the doors...first. then decide and a choice of corner joints...and whether to add a bread board edge to the doors. 90 minute in the shop, today...still have to bring the clothes upstairs from the dryer.. Stay tuned..
From the album: Spokeshave case, from scrap wood
- 1 comment
- ash box
- spokeshave holders
(and 1 more)
- ash box
(and 1 more)
- ash box
(and 1 more)
- ash box
(and 1 more)
- ash box
(and 1 more)
- ash box
(and 1 more)
- ash box
(and 1 more)
