August 22, 201412 yr comment_343 What is the difference from a mortise router bit and a spiral up cut for box joints?Can they both be used to make a box joint? Report
August 22, 201412 yr comment_345 Spiral up bits are usually used on router table operations. Here's an article comparing the various straight cutting bits- http://www.woodcraft.com/Articles/Articles.aspx?ArticleId=445 Spiral bits cut a little cleaner and are better for plunge operations. I've cut box joints with both. Report
August 22, 201412 yr comment_344 And really depending on where you are going to use this. If you are going to use it in a table router you would probably want a down spiral for the box joints. That way it is pulling the shavings down into the table for the dust collector to take away. If you are using it in a hand held router, then the up spiral will lift the shavings and if you have dust collection it makes it easier to get rid of the shavings and dust. A straight bit will also work for the box joints. The dove tail jig I have will also do box joints and you just use the straight bit. Report
September 4, 20188 yr comment_158848 Old topic, still a great question. Moved up from the archives Report
September 4, 20188 yr comment_158852 It's been a while, now. Which one did you choose, @Ron Altier? And, how did it work for you? Report
September 5, 20188 yr comment_158927 I have the Incra BJ jig and I set it up on my router table and got a lot of tearout on the outside of the board. I now use it on the table saw with no tearout. Report
