May 26, 20251 yr comment_356802 Haven't tried this but can I ask your bowl gouge orientation? Are you using a push cut? I believe a planing pull cut would be best for these. I would also definitely cut the blanks with a hole saw and just eliminate having to remove the corners. Report
May 26, 20251 yr Author Popular Post comment_356803 Steve, I tried both push and pull, the pull definitely worked better. As it is I've got everything done now, but I do thinks cutting the blanks with a hole saw would have made life a little easier. Report
