Posted
Agree completely with your conclusions, based on roughly similar (if thinner!) experiences over the years.
I see dowels as joints to be a poor substitute for a mortise and tenon and I think they are largely used because that is what large scale furniture manufacturers do.  Such furniture lasts a few years only, make a few decades if lightly and rarely used - but those joints always seem to come loose eventually.  Somewhere I have a high quality dowel jig that a more experienced guy gave me 30 years ago, and I've used it as little as he did over the years.
On the whole, I have mostly replaced doweling with glued and pocket screwed butt joints where an M-T is overkill (NOT in chairs for example, there an M-T is required).  The tension on the screw shaft keeps the butt joint tight and the glue helps prevent the wracking forces that will work the screws loose.  I still don't see it as a century joint, but it works better than dowels where it works.
  • Like 2
Posted
Agree with you also. I have never been a fan of dowel joints. And like you most failures in furniture I've seen are those type joints.
  • Like 2
Posted
The only good use for a dowel in a joint, IMO, is to pin a tenon.   Many year ago, early in my teaching career, I taught a beginning computer class.  1982ish. As there wasn't yet a big monitor or projector in every room like there is now, I had to lug a PC with a big monitor back and forth from my office to the lecture room.  Made a rolling gate legged table to support a swing up hinged top. had to keep the whole table narrow to fit through doors.  Casters big enough to roll easily over variations in the wood floor of the ancient building I taught in.  Mortise and tenon joints between every stretcher and vertical leg were then  pinned with a 1/4" dowel through one side.  At some point as technologies advanced the need to roll a PC/Monitor around went away, so I brought the table home.  Thought I'd take it apart to salvage the wood used.  I suppose I could have drilled out the dowels.  Couldn't just knock them through.  The tenons had been snug and no rack every developed in the table despite it's rolling life adventures.  Finally I just cut the stretchers from the legs to get it apart.
4D
  Only 75 emoji are allowed.
