June 7, 20242 yr comment_336863 Need Help, not sure if this is the right forum, so please move if not. My daughter was given a large shopping bag full of drums for a drum or spindle sander, thought I could use them. This bag has everything from 1"x2" to 3"x3" all from Klingspor. I do not have a spingle/drum sander (not at this point). I am not familiar with them, do they have interchangeable drums? can you get drums to fit on a router? Educate me. Edited June 7, 20242 yr by Lost Oki better understanding of what I am describing Report
June 7, 20242 yr comment_336865 Spindle sanders have interchangeable drums, but generally speaking drum sanders do not. The size of those drums you have make me think they fit a drill press spindle or something like that. Report
June 7, 20242 yr comment_336866 I agree with Fred. Harbor Frieght has a set that takes those sizes. https://www.harborfreight.com/4-piece-quick-change-sanding-drum-set-35455.html?utm_source=google&utm_medium=cpc&utm_campaign=12126402660&campaignid=12126402660&utm_content=118354993113&adsetid=118354993113&product=35455&store=3336&gad_source=1&gclid=CjwKCAjw34qzBhBmEiwAOUQcF8kgT_ZwhLqAo1Dmx-gWTq_CKNJiGzclTuynfFSFFPJsGVO1_6N4eRoCibgQAvD_BwE Report
June 7, 20242 yr comment_336870 In addition you cannot sand with a router. In addition to what Fred said oscillating spindle sanders usually have several different size drums which may vary in diameter from one manufacturer to another , Report
June 7, 20242 yr Author comment_336873 Thanks gentlemen. Following up on your info I am beginning to think these sanding drums are for an Oscillating spindle sander. Don't have one, never used one but after researching, I believe there might just be one in my future. After all, when opportunity presents its self....Also, forgot to ask, is Klingspor products of good quality? Report
June 8, 20242 yr comment_336875 49 minutes ago, Lost Oki said: Also, forgot to ask, is Klingspor products of good quality? Yes they are. Sanding sleeves have glued seams. You may experience failure if the sleeves are very old. Report
June 8, 20242 yr comment_336879 Most of the drum sanders come with them included, I'm not sure you'll find an advantage to having the ones you have. Report
June 8, 20242 yr comment_336891 2 hours ago, Fred W. Hargis Jr said: Most of the drum sanders come with them included, I'm not sure you'll find an advantage to having the ones you have. I meant most of the spindle sanders come with a set of sleeves. Report
June 8, 20242 yr comment_336901 13 hours ago, Lost Oki said: Thanks gentlemen. Following up on your info I am beginning to think these sanding drums are for an Oscillating spindle sander. Don't have one, never used one but after researching, I believe there might just be one in my future. After all, when opportunity presents its self....Also, forgot to ask, is Klingspor products of good quality? Just a heads up. Most oscillating spindle sanders use a 4 1/2" long sanding sleeve. I imagine the 3" could be used but not sure with the up and down travel. Edited June 8, 20242 yr by HandyDan Report
June 9, 20242 yr Author comment_336919 13 hours ago, Cal said: Can you post up a pic of what you have? There are 5 bags of the 3'x3', 2"x2" and 5 of the 1"x2" plus assorted. I am guessing that the drums and parts fit an oscillating sander. Talking with daughter, the lady and sold all the tools and then found these in a box so she gave them away. Sure wish I had been at the sale. Edited June 9, 20242 yr by Lost Oki Report
June 9, 20242 yr comment_336920 24 minutes ago, Lost Oki said: I am guessing that the drums and parts fit an oscillating sander. Most definitely, now ya gotta get one! Report
June 9, 20242 yr comment_336925 They sure look a little short for an spindle sander I've seen. Like Dan said, most of them (the benchtop models) use 4 1/2" sleeves. My guess is this is for more of a drill press arrangement, they use the shorter drums. That's quite a pile you have, hope you come up with a use for all of it. Report
June 9, 20242 yr comment_336927 48 minutes ago, Fred W. Hargis Jr said: They sure look a little short for an spindle sander I've seen. Like Dan said, most of them (the benchtop models) use 4 1/2" sleeves. My guess is this is for more of a drill press arrangement, they use the shorter drums. That's quite a pile you have, hope you come up with a use for all of it. I am agreeing with Fred for the reason stated. You could get the Harbor Freight (Go H-F!) set and be in business. Not sure what size those belts are. Report
June 9, 20242 yr Author Popular Post comment_336963 Some of these sleeves will work with my drill press, others I can cut and use with my dremel's. others will require spindles. Harbor Freight has the Sander but only 1/5 hp, Lowes and HD have one with 1/2 hp. Now to hit the CFO for an early birthday present. Thanks again for all the info. Check the break room for Donuts. Report
June 9, 20242 yr comment_336964 I have the Rigid sander and I believe a lot of the others do too. Report
June 10, 20242 yr comment_336979 17 hours ago, HandyDan said: I have the Rigid sander and I believe a lot of the others do too. Do you like this sander Dan? There is one up at the local HD & Lowe's outlet that I've seen and thought about getting it for my daughter. It may have been a display model for it is coated with dust (not sawdust). Report
June 10, 20242 yr comment_336984 1 hour ago, Cal said: Do you like this sander Dan? There is one up at the local HD & Lowe's outlet that I've seen and thought about getting it for my daughter. It may have been a display model for it is coated with dust (not sawdust). I've owned one for several years. A right handy sander. Report
June 10, 20242 yr comment_336988 2 hours ago, Cal said: Do you like this sander Dan? There is one up at the local HD & Lowe's outlet that I've seen and thought about getting it for my daughter. It may have been a display model for it is coated with dust (not sawdust). Have had it for years and love it. It quit on me once. Blew it out with compressed air and it has been running since. Report
June 11, 20242 yr comment_337024 Plus one on those comments and like Dan mine did quit once but the cleanout worked. Report
