Popular Post Gerald Posted September 4, 2022 Popular Post Report Posted September 4, 2022 Started work last month on a platter test which I have not completed and this pic is not all I have done to this test in pine. The methods used so far in this one were round Saburr tooth burr plunged end on, dremel style saw blade ( this has since been burned to enhance), carbide round burr and metallic gourd ink. So now I have started a pecan platter from one of the blanks left from the offering plates two years ago. Had to fill a bit for inclusions which are common with pecan. Used epoxy slow set with black mica powder for that. as I was hollowing it came off chuck and lost a chunk requiring more epoxy. more tomorrow I hope. Fred W. Hargis Jr, HandyDan, John Morris and 2 others 4 1 Quote
lew Posted September 4, 2022 Report Posted September 4, 2022 Those are some interesting patterns, @Gerald. Were you using the vacuum chuck when the piece came loose? Cal 1 Quote
Gerald Posted September 4, 2022 Author Report Posted September 4, 2022 1 hour ago, lew said: Those are some interesting patterns, @Gerald. Were you using the vacuum chuck when the piece came loose? No had it on in expansion mode on chuck 100mm. Had the tailstock up till working on hollowing and then just took too big of a cut. Seem I always forget that principle ....small cuts. Cal and lew 2 Quote
Steve Krumanaker Posted September 5, 2022 Report Posted September 5, 2022 13 hours ago, Gerald said: No had it on in expansion mode on chuck 100mm. Had the tailstock up till working on hollowing and then just took too big of a cut. Seem I always forget that principle ....small cuts. I hate it when that happens!! None of those particular embellishments really do it for me but I get the process. You never know when something is just going to pop! Cal, Gerald and lew 3 Quote
HandyDan Posted September 5, 2022 Report Posted September 5, 2022 The embellishing looks are too tedious for me. I get tired of messing with them and haven't been successful with any. Cal and lew 2 Quote
Gerald Posted September 7, 2022 Author Report Posted September 7, 2022 Finished the embellishments on this today. Will be couple days before I get to apply lacquer. The Eagle was done with a stick n burn and colored with pencils. Dots cut using Wecher carver and a carbide bit. Cal and HandyDan 2 Quote
lew Posted September 7, 2022 Report Posted September 7, 2022 Really like the eagle. Nice save with the epoxy filled defect on the rim Gerald and Cal 1 1 Quote
HandyDan Posted September 7, 2022 Report Posted September 7, 2022 Nicely done. Like the coloring. lew, Ron Altier and Gerald 2 1 Quote
Ron Altier Posted September 9, 2022 Report Posted September 9, 2022 Beautiful piece. I know it took a lot of time and creativity. Most of all.....I know you enjoyed all of the time you spent creating it. Gerald and lew 1 1 Quote
Gerald Posted September 13, 2022 Author Report Posted September 13, 2022 Got the red lacquer applied and this is the finished platter. Fred W. Hargis Jr and Artie 1 1 Quote
lew Posted September 13, 2022 Report Posted September 13, 2022 2 hours ago, Gerald said: Got the red lacquer applied and this is the finished platter. Gorgeous! Gerald 1 Quote
