April 6, 20224 yr Popular Post comment_287835 Here's a good video on the subject. Note you could also just mortise both sides and cut some floating tenons, too. Or you could go to PopWood's site and pay $4 for the video. http://mycrafts.com/diy/mortise-tenon-joinery-with-a-router/ Report
April 7, 20224 yr Popular Post comment_287893 Have done it with router but used a router table. It is a bit tedious but when cutting 24 after setup is fast. Report
April 11, 20224 yr comment_288126 Before I had a CNC where I could clamp parts vertically I preferred to cut mortises on the router table just as Gerald mentioned. Tenons to fit I usually used the table saw to cut the shoulders then with a tenoning jig cut the sides. Band saw to cut the ends and a chisel to nip the corners to fit in the round end mortise. While most of the glue is between the faces as the video stated a snug end help keep the joint from racking. Getting the joint lined up was never a problem with careful layout. 4D Report
