February 21, 20224 yr Popular Post comment_284683 17 minutes ago, steven newman said: Looks like these 2 had a baby....happens when you leave 2 blocks planes alone in a drawer.. You should see what happens if you leave a banjo and an accordion in an unlocked car while running into the convenience store! Report
February 22, 20224 yr Popular Post comment_284691 2 hours ago, steven newman said: Ready for the $0.05 Tour? You accept plastic? Bandit, I have to say, most organized the dungeon has been in some time. You'll never find anything now especially those pencils you stashed in the Benchtop organizer. Thanks for the tour. What time does the snack bar close? Report
February 22, 20224 yr Popular Post comment_284694 What are your expansion plans Steven? Spring is right around the corner... Report
February 22, 20224 yr Popular Post comment_284718 I keep wondering when do you find the time to use all those planes. I can see another layer in that cabinet developing. And where do you get your storage ideas? Report
February 22, 20224 yr Popular Post comment_284727 19 hours ago, Dovetail said: You should see what happens if you leave a banjo and an accordion in an unlocked car while running into the convenience store! Do you know which hits the ground first if you throw a banjo off a 10 story building, then two seconds later throw off the accordion? Let's try it and see. Report
February 22, 20224 yr Popular Post comment_284728 On 2/17/2022 at 12:44 PM, frenchwwr said: Right, because adding horizontal space in a shop has always solved a tool storage problem I built two 4x8 work tables when the theater group got their new shop. They were the right height to be outfeed tables when needed. When we started the last build, one of them was piled with stuff. Scraps of wood, paint cans, buckets and boxes of hardware. I put a sign on it, "This is not a junk table." It did not help a lot. Report
February 25, 20224 yr Author comment_284915 Had one more spot to clear out... Might see what I can cobble up for this spot...or, just remove the mess entirely. When I work on Chester Drawers....I can lay the case from the bench over and rest on that up-right. Thinking about building a stand to put the drill press on.....as it is in the way where it is at. Maybe include the Grinder with it? Or...just leave the grinder there, add a base to the drill press, to where I can clamp it to the end of the bench when needed...Hmmm... Report
