Popular Post Artie Posted January 2, 2022 Popular Post Report Posted January 2, 2022 So probably everyone who reads this knows I make lots of the Kissmas Trees from the Woodcraft magazine. I have used Poplar on all of them so far. When I drill the pockets for the kisses, sometimes the bottom of the pocket gets splintery/raised grain. This doesn’t help the painting process. I was thinking of trying Pine instead of Polar. It’s less expensive, and there really isn’t much of a bearing load . Any reasons why Pine instead of Poplar is a bad idea? lew, Grandpadave52, FlGatorwood and 2 others 5 Quote
Popular Post sreilly24590 Posted January 2, 2022 Popular Post Report Posted January 2, 2022 One quick thought, would using a router bit to carve out the pocket maybe do a better job? I was thinking of a bit like this might do a better job but then again I'm unfamiliar with these trees. Have a picture of one of your's can post? Grandpadave52, Al B, lew and 2 others 5 Quote
Popular Post Gene Howe Posted January 2, 2022 Popular Post Report Posted January 2, 2022 Good idea, Steve. With Artie's Power Pro, turning that bit to speed would be easy. Keep it in horizontal drilling mode and flip the branches. Batch them out quickly. FlGatorwood, Headhunter, Cal and 3 others 6 Quote
Popular Post Al B Posted January 2, 2022 Popular Post Report Posted January 2, 2022 Artie, What are you using for a drill bit ? If you're not already using one, maybe a forstner bit would eliminate the problem. Or maybe as suggested by others, a router bit. HEY, I've got 3 dead poplars standing on my property. You're welcomed to them. KevTN, Cal, FlGatorwood and 3 others 1 5 Quote
Popular Post JimM Posted January 3, 2022 Popular Post Report Posted January 3, 2022 (edited) Your choice of finish might be a consideration. I've found that pine is pretty pitchey (is that a word?) which could affect the finish. If you're leaning toward a softer wood, I've had good luck with basswood. It's easy to find in my neck of the NE, and priced like clear pine. Just my $.02. And x2 what Al said. Edited January 3, 2022 by JimM FlGatorwood, lew, Grandpadave52 and 2 others 5 Quote
DAB Posted January 3, 2022 Report Posted January 3, 2022 don't drill pockets? FlGatorwood, lew, Cal and 1 other 4 Quote
Smallpatch Posted January 3, 2022 Report Posted January 3, 2022 Artie if you are using a forstner bit only go until the tip sticks out the bottom of the wood then turn the wood over and drill from the bottom. This gives you a smooth edge of the holes from either direction. The old type hole saws with the drill bit sticking out drill until the drill bit sticks out the bottom then flip the wood over and finish drilling the hole. It gives the same results as the forstner bit but not as professional looking. If drilling lots of holes in the same thickness set the depth gauge so the bit stops the same each time so there won't be any guessing. lew, Grandpadave52 and Cal 3 Quote
FlGatorwood Posted January 3, 2022 Report Posted January 3, 2022 I am with AlB about using a Forstner bit. Usually cuts the hole rather cleanly. Paddle bits will tear and splinter the wood. lew, Grandpadave52 and Cal 3 Quote
Popular Post Artie Posted January 3, 2022 Author Popular Post Report Posted January 3, 2022 I’m hoping this picture and my post will explain things. There are 30- branches if you will with no pockets in the very bottom one. So 29 branches with an average of 4 pockets per branch, 116 pockets. I started with a 7/8 Fisch Wave Cutter Forster bit, but some of the Kisses didn’t sit in it as much as on it, so I got a Fisch Wave Cutter 15/16 Forster bit. (Only place I found where I could order just the 15/16 bit was Highland Woodworking) I thought that after making roughly 21 of these trees maybe the bit had gotten dull, so I bought another one. (Cause I don’t know if you can sharpen a Forster bit, but I sure can’t ) I’m not sure of one of those router bits would cut, coming straight down like a Forster bit. I use a milk paint (General finishes I think) Westminster Green. Here’s a picture. I was thinking pine cause I can get that at a BORG pretty cheap. lew, Cal, Grandpadave52 and 3 others 6 Quote
Artie Posted January 3, 2022 Author Report Posted January 3, 2022 Dab, absolutely, no pockets would halve the time to make these, but I think the pockets make i a better piece. I have tried a find a Forster, hole saw, or some other bit that would cut the hole without the center hole, but haven’t found one. I don’t think that bull nose router bit would drill effienctly straight down. Cal, FlGatorwood and Grandpadave52 3 Quote
Popular Post lew Posted January 3, 2022 Popular Post Report Posted January 3, 2022 I was thinking that maybe a plunge router with one of these https://www.toolstoday.com/v-13371-45182.html Gunny, Cal, KevTN and 2 others 5 Quote
Wichman3 Posted January 3, 2022 Report Posted January 3, 2022 Artie, what are you using to secure the piece while drilling? A jig and clamp? Or just hand pressure? Grandpadave52, Cal and FlGatorwood 3 Quote
Artie Posted January 3, 2022 Author Report Posted January 3, 2022 Lew, I ordered one. I dunno how easy setting up a jig for a plunge router would be? The SS Pro max’s at 10,000 RPM, but it’s easy to set up drill press mode. It will probably take longer, but if it has a noticeably cleaner cut than I’ve got the time. My requests are up to 8 more trees. I’m just thinking that pine would be softer, so maybe easier/cleaner cutting? lew, Cal, Grandpadave52 and 1 other 4 Quote
Artie Posted January 3, 2022 Author Report Posted January 3, 2022 2 minutes ago, Wichman3 said: Artie, what are you using to secure the piece while drilling? A jig and clamp? Or just hand pressure? So far I’ve been using a Southbend drill press, with a drill press table. There’s a fence with stops, and I just use hand pressure to keep the piece in place against the fence and stop. Grandpadave52, FlGatorwood and Cal 3 Quote
Wichman3 Posted January 3, 2022 Report Posted January 3, 2022 I would highly recommend some sort of clamp, either the vice grip style drill press clamp https://www.harborfreight.com/9-inch-drill-press-locking-clamp-36221.html or a jig with a toggle clamp https://www.harborfreight.com/500-lb-vertical-toggle-clamp-96238.html one issue with tear out is the piece moving while it's being drilled, these methods would eliminate that movement. And they are not expensive. Grandpadave52, FlGatorwood, Artie and 1 other 4 Quote
Popular Post Smallpatch Posted January 3, 2022 Popular Post Report Posted January 3, 2022 Well now that I know what you are doing I can answer more knowledgeable. A forstner bit will drill the desired depth but before you pull the bit out of the hole let it turn on the bottom of the hole a few seconds and that will knock off the fuzzies. I hope you are using a drill press for you can set it so all the holes are the same depth. Why are you not liking the guide hole in the middle of the hole. It's there so like it! But if you are using a drill press you could grind off the guide and the hole would be flat but then it would be useless with a hand held drill. The worse pine to use is Southern Yellow Pine for it has some very hard and soft spots close together and will make it very hard to drill in exact spots when using the hand held drill. I don't like poplar because of the fuzzies and getting a good smooth finish with paint takes lots of extra time. Artie, Grandpadave52, Cal and 3 others 6 Quote
Artie Posted January 3, 2022 Author Report Posted January 3, 2022 1 hour ago, Wichman3 said: I would highly recommend some sort of clamp, either the vice grip style drill press clamp https://www.harborfreight.com/9-inch-drill-press-locking-clamp-36221.html or a jig with a toggle clamp https://www.harborfreight.com/500-lb-vertical-toggle-clamp-96238.html one issue with tear out is the piece moving while it's being drilled, these methods would eliminate that movement. And they are not expensive. The drill press table came with clamps, I can use them on one tree and see how much of a difference I get. It will take much longer, but if the hole is what I want, well I got the time. lew, HARO50, FlGatorwood and 1 other 4 Quote
Popular Post Gerald Posted January 3, 2022 Popular Post Report Posted January 3, 2022 Forstners can be sharpened. Here is a video but there may be other methods. Artie, Gunny, HARO50 and 4 others 4 3 Quote
Popular Post Headhunter Posted January 3, 2022 Popular Post Report Posted January 3, 2022 Artie, The bit Lew showed will work well with your SS in horizontal boring mode. Or drill press if you want to take the time to do the setup. Easy to align and move the workpiece against the fence and the depth stop will insure consistent holes. I used to do this when I was making stuff for the trophy shop with walnut and never had any issues with it. Poplar or pine should be a breeze. Gunny, HARO50, FlGatorwood and 4 others 7 Quote
Popular Post Wichman3 Posted January 3, 2022 Popular Post Report Posted January 3, 2022 I would also set the drill press speed at the top of the rated speed or one step higher on the drill press speed (pulley system). HARO50, Grandpadave52, Artie and 4 others 7 Quote
