January 14, 20215 yr Popular Post comment_254572 I have had a problem for a while in the shop with the crank handle on the planer. It juts out into the narrow walkway between the jointer and the planer and I have an ongoing set of hip bruises as a result. The solution was to turn a handle that has a wooden tenon that I can just insert into the threaded hole for the handle and only when I need it. It probably won’t last forever but hopefully for a while. Report
January 14, 20215 yr Popular Post comment_254574 Love the idea, one question. Where do you put it when not in use? Because if it were me I would lose it if I didn't attach a chain to it. Report
January 14, 20215 yr Author Popular Post comment_254575 The plan is to pick up a brass eyelet and tie it to the machine. I will definitely lose it otherwise. Paul Report
January 14, 20215 yr comment_254580 23 minutes ago, Masonsailor said: The plan is to pick up a brass eyelet and tie it to the machine. I will definitely lose it otherwise. Paul Piece of PVC pipe with a bottom made to it then mount to your machine. This way you don't tie yourself up, again because I would do that. LOL Report
January 14, 20215 yr comment_254590 Great idea. We get enough aches and pains. Happy to see you rid yourself of one. Report
