December 7, 20205 yr Author comment_250266 yes it is I did check to make sure that was level and it is locked down and good. Report
December 7, 20205 yr comment_250267 Next step, loosen the tail stock end mounting bolts and check for level Edited December 7, 20205 yr by lew Report
December 7, 20205 yr comment_250270 OK, then either the head stock, or tail stock should have adjustments for alignment. Might have got knocked out of alignment during a move. Report
December 7, 20205 yr comment_250272 Just now, Larry Buskirk said: OK, then either the head stock, or tail stock should have adjustments for alignment. Might have got knocked out of alignment during a move. Larry, I looked at the HF manual and there doesn't appear this model has adjustment bolts. https://usermanual.wiki/Harbor-Freight/HarborFreight12InX3338In34HpWoodLatheWithReversibleHeadProductManual723278.1452600896 Report
December 7, 20205 yr Author comment_250273 Ah adjustment bolts no it doesn't I was thinking you were referring to the bolts that I had used to bolt the lathe down to the bench itself. Report
December 7, 20205 yr comment_250274 1 minute ago, AndrewB said: Ah adjustment bolts no it doesn't I was thinking you were referring to the bolts that I had used to bolt the lathe down to the bench itself. Try loosening the bolts that hold the lathe to the bench and then check to see if the lathe ways are level. Just loosen the those bolts on the right end (tailstock end) to start with. You may end up having to loosen both ends and then shimming as you tighten them back down to keep the ways level.. Report
December 7, 20205 yr comment_250275 4 minutes ago, AndrewB said: Ah adjustment bolts no it doesn't I was thinking you were referring to the bolts that I had used to bolt the lathe down to the bench itself. Lew was, I was hoping there were alignment bolts for either the head stock, or tail stock. But it doesn't appear so. Report
December 7, 20205 yr Author comment_250276 I'll have to see if that works again... But I've done that once with the lathe at one point already unfortunately. Sadly Centeral Machinery has SHOTTY specifications for these things. Its not right in the end. But at some point in the future I will be getting a new lathe. Report
December 7, 20205 yr comment_250279 Try checking the alignment with the head stock lock just barely loosened. I'm wondering if overtightening might be pulling the head stock. Report
December 10, 20205 yr comment_250580 I may be way off base here, but I would start by checking with a level from end to end of the work bench, then check across from front to back all along the length of your bench. If all that is level, then the ways should both be level. If not, then as suggested, shim the low places and bolt the unit back to the bench. You can put washers on top of the lathe around the bolt if it is too long or a shim on the bottom of the lathe to make the bed level. I hope you have complete success. Report
