Posted
For a full run down on this project and rules please go to: "The Patriot Woodworker and MWTCA "What's It" project"
Additional What's It Rules
  • Unless you are completely sure what this item is, please avoid "definitive statements" that appear that you are without a doubt claiming that you know what the item is. For example stating, "this item is called a "widget xx" used for "insert purpose here". If you are making a definitive statement you must accompany your statement with evidence or proof from a secondary source.
  • An example of acceptable statements within the realm of having fun and educated guesses would be something like this, "I believe it could be", or "It appears it's made for this or that", etc etc etc...
Ok ladies and gentlemen, we now have our "What's it" live and ready!
Project Details
The information provided hereon is all the information that is provided, no further information on this item will be added.
  • Like 2
Posted
:huh:...Well I'll be danged, that's the second one of those I've seen recently.
The neighbors got one, and asked me if I knew what the heck it was. ..:WhoMe:
I do know if you move the handle the pullies move into the heart shaped outer metal ring like some kind of brake.
  • Like 2
  • Thanks 1
Posted
Looking at the construction that action appears to be the bands would tighten around the wheels when the lever is actuated.  The wheels look flat on the outside and no place to insert anything.  I even make  a silly a&& guess as to what it could be used for.
  • Like 2
Posted
Dan,
The wheels (Had pullies on my mind:rolleyes:) actually move into the band when you move the lever.
On the one my neighbor has the slot in the handle is big enough for me to fit 3 fingers into.
I couldn't find any markings on the one he has to help identify what the heck it is/was. 56567ea584735_IDontKnow.gif.3cfca1eb302acab6008082f8235203b6.gif
  • Like 2
Posted
Thinking this works in conjunction with a single pulley, like a block and tackle to raise or lower a heavy object, like a large door
  • Like 2
Posted
26 minutes ago, Larry Buskirk said:
Dan,
You should get that from your neighbor and dissect it.  It is really hard to visualize what moves when the wheels are mounted a solid frame.  I feel the band assemble and the wheel assemble move into each other somehow.
  • Like 3
Posted
@HandyDan,
I'll check if he still has it, or knows where he put it. He might have put it out for sale.
If you look at the center photo the slotted part below the handle slides back and forth, the bands are connected to this center section. It may very well be that both parts move together.
It was 2 or 3 weeks ago I played with it trying to figure out what it is/was.
  • Like 2
Posted
The handle pushes the wheels forward to brake a shaft that is in the hole on the bottom. Maybe to control the speed instead of totally stop the shaft.
  • Like 2
Posted
The hole is fixed and so are the wheels.  The only part that can move is the heard shaped band.
  • Like 2
Posted
It acts looks and performs like a hand brake to something.  To what, I don’t know.  I wonder how it attaches.
Posted
I was wondering the same thing Ron.
The hole doesn't go all the way through.
  • Like 2
Posted
 My guess would be some sort of tensioner similar to what's used on a reel to reel. Used to apply tension to a band or ribbon.
 The first photo shows a hole and the back of three studs. The hole would mount to a stud on a piece of equipment with nut & washer, based on the wear of the other studs.
 Two studs on the back hold the round dowels, threaded on the opposite end to accept the screws.
 The photo shows a third stud in the middle the I believe to be a rod.
 The flat plate on the top I believe is fixed to the back mounting plate maybe brazed on the inside. A 90 degree bracket with 2 rivets to hold it and threaded to accept the screw.
If you would remove the three screws and pull the plate back with the handle this would allow access and then you could insert a band or ribbon over the dowels and under the rod. The spring would adjust the tension. The lack of wear on the spring has me thinking that nothing moves through this but is use with other parts that require the tension.
Posted
I’m going to agree fully with Bob.  In fact, I wrote something similar to his explanation, read his and erased mine.  Think banding machine.
Posted
Reminds me of a manual tensioner.  A belt could run along the outer smooth surface.  Kind of like a belt sander tensioner.
  • Like 2
Posted
Ok now for a slightly different take . Looks like a feed rate adjustment. The thread or banding goes thru behind the plate above the wheels. This item might be thick so do not think film but more like banding. The tension is applied not by pushing the handle down but pulling it up to expand the band toward the plate. Also a possibility that this is for alignment and not tension.
  • Like 2
Posted (edited)
Might be use to REPAIR a belt.....as in the belts that drove this..
Because the "slide" attached to the handle slides TOWARDS the wheels....instead of moving the wheels.   It may also pull the outside plate towards the wheels.   The wheels are more like guides, that rotate when the slide goes by, guiding it along.....Could also be a hand brake....that "hole" could be for a bracket that fit into that hole, and was attached to a machine by that bracket.   Maybe while the operator was doing set-ups on a lathe,  when done, release the "belt clamp" and the lathe will start running again...
Edited by steven newman
  • Like 2
  • 4 weeks later...
Posted
Winner
@DuckSoup has been selected as this months MWTCA Membership recipient.
Since a verifiable answer was never arrived at for this item, we went to random draw.
Award
Bob, for your participation you have won a 2020 Calendar Year membership into the MWTCA.
Please Private Message me your contact info, shipping address, spouse or significant others name (if applicable).
Thank you all for your participation!
Links
Gristmill Magazine Sample
the gristmill
Posted (edited)
Congrats Bob.
Edited by HandyDan
  • Like 3
  Only 75 emoji are allowed.
