I not sure where to post this so if I'm wrong please move it.
A saw mill is all about wood so I thought I would post it here.
I was going to wait to start posting anything new until I finished
reading all the post on this forum but I'm only on page 64 of
general woodworking and it's taking forever. I have lots of wood
working machines that I have built that will be posted sometime
later. The hardest parts to find when building a band mill is the wheels.
I did some welding at Grizzly tools and took in trade these two band
wheels for payment. I think I got the better deal. I bought a boat
trailer and narrowed it down. If I knew what I know today I would
have left it wide. If your going to make one make it as wide as you can.
I have the mill built and in use but I'm going to post the build from
the beginning. I started out putting 6" channel on top of the boat
frame for my carriage track. I will be glad to answer any questions
anyone has.
Highly interested in the progression of this topic, great start Kevin, waiting for future installments! I pinned this one to the top so we can find it easily.
Let me get the popcorn, @Gene Howe we are going to need more liquor.  Should be a interesting thread.
Forget the reading all the old post keep these coming!!:TwoThumbsUp:
But I'm learning so much reading them....
When I started building this mill I really had no idea what I was
doing. Right behind my home is a Frick mill with a 600hp diesel
engine and it and cut 50ft long lumber. It always looked like work
to me and I wanted nothing to do with it. When my father passed
I got the land and it had lots of Hemlock on it and it was all dying.
So I got the bright idea that I would make a mill. No sawmill wanted
to buy infected Hemlock trees. I wish I had worked with or for
someone that had a band mill before I made mine. Then I would
have seen what I really wanted. But I'm still very happy with the
way my mil turned out. I do welding, fabrication, electrical, hydraulics,
machining and wood work. So making this was easy and fun for me.
The reason I said to make your mill as wide as you can is that wide
wood sells so easy. My mill is plenty big enough to cut any tree on
my farm but I was not expecting all the free BIG logs that everyone
wants to just give to me for free.
Back to the build...
I got three 6" channels down each side of the trailer counting
the trailer framing. I want this mill to be tough,
Edited by Kevin Beitz
That is some piece of work.  Impressive!!
Lots of welding...
The big pulley pulls the carriage along.
Battery box is for two 12v batteries because everything will be 24 volts.
Being self employed is great because you only have to work half days! That would be the first half or the second half .JPG
How big of a diameter tree can this thing cut?
I've done 30" logs. You got to cut the round tops off and flip
to get it between the 25" blade guides.
I can do 26' 3" long now but it's so easy to make another extension
to go longer if needed.
Very cool build Kevin.
Not to change the subject, but tell me about the hemlock that somewhat necessitated this build.  What is it infected with?  An insect, or some type of viral disease that can be spread by equipment moving from place to place?  The lumber itself must be usable, after kiln drying?
It's the hemlock woolly adelgid. Feeds on the plant sap.
The trees can still have green tops but when I saw them
the wood is punky. Now worth the time and work sawing them.
This summer I could here about one tree a day falling crashing
in my woods. It's to bad because that's what I had the most of.
Had to look that up Kevin.  Thanks for the info.
Using wheelchair 24 volt motors for movement of the carriage up/down and log cutting travel. DC control boards for variable speeds.
DC 10-50V 60A Motor Speed Control PWM HHO RC Controller 12V 24V 48V 3000W.jpg
The brace legs is made from 1-1/2" ID heavy wall pipe with 1-1/2" OD solid cold roll round that can be adjusted in or out to match the ground level. 6" round X 3/8" plates for the feet. They have worked out well.
That plate under the foot is a great idea. Looking good
I had to sneak this this one in here. Just finished cutting the longest
log ever on my mill. I'm building another building here at my home
and I needed a 25 foot 10x10... Anyone want to help lift this one up?
It's 25 feet 9 inches long.
Only need one helper, huh? looks to me like 5 or 6 , all with arms like Hulk Hogan.
