March 25, 20197 yr comment_183966 I'm making a crosscut sled for my table saw. I'm using 3/4" BB plywood. I've seen lots of plans and a few have used zero clearance inserts for the sled and/or the fence. Do you find this to be a worthwhile feature? I would route recesses in the sled and fence and use 1/4" hardboard for the inserts. Report
March 25, 20197 yr comment_183975 It would certainly be an asset. Great idea for the replaceable insert of hard board. My DP table has one and it works great. The only concern for one on the sled would be how to keep it from picking up. Maybe screws outside the cutting area? Let us know what you do. Report
March 25, 20197 yr comment_183979 I'm a little confused! Why would you need a zero clearance insert for a cross cut sled? Typically, when you cut the sled with the blade it only cuts a slot the width of the blade. If you are talking about the back of the sled and the "pass-through" getting chewed up, then just again, why? The material is being held and just gets cut...worried about chip out on the material...use a backer. What am I missing? Report
March 25, 20197 yr Author comment_183985 5 minutes ago, Gene Howe said: It would certainly be an asset. Great idea for the replaceable insert of hard board. My DP table has one and it works great. The only concern for one on the sled would be how to keep it from picking up. Maybe screws outside the cutting area? Let us know what you do. @Gene Howe I just finished the DP table (WoodSmith Plan) with the replaceable insert....15 degree angle on the edges hold it in place. You had provided feedback on my choice of contact cement, brayer, etc. For the table saw sled most of the plans called for securing the insert(s) with countersunk screws which is the way I would go. I'll just route recesses for the inserts. Had I used 1/2" ply for the sled I would have just added 3 pieces of 1/4" hardboard for the top surface.....similar to the DP table. I'm thinking that 1/4" Hardboard on top of 3/4" ply will be too thick and too heavy. Report
March 25, 20197 yr Author comment_183988 10 minutes ago, schnewj said: I'm a little confused! Why would you need a zero clearance insert for a cross cut sled? Typically, when you cut the sled with the blade it only cuts a slot the width of the blade. If you are talking about the back of the sled and the "pass-through" getting chewed up, then just again, why? The material is being held and just gets cut...worried about chip out on the material...use a backer. What am I missing? Maybe use a dado set with the sled. Maybe the same reason for using a zero clearance insert.....thin kerf vs full kerf blades. I would agree that if the same blade is used every time that the original slot cut would be a zero clearance insert. Report
March 25, 20197 yr comment_183989 1 minute ago, JIMMIEM said: Maybe use a dado set with the sled. Maybe the same reason for using a zero clearance insert.....thin kerf vs full kerf blades. I would agree that if the same blade is used every time that the original slot cut would be a zero clearance insert. Dado blade! It is just as easy to bury the dado blade in an auxiliary fence and just use a miter gauge on the table saw. Just my 2¢. Report
March 25, 20197 yr comment_183991 7 minutes ago, schnewj said: Dado blade! It is just as easy to bury the dado blade in an auxiliary fence and just use a miter gauge on the table saw. Just my 2¢. Quite true for a rabbeting cut. A ZCI would be nice for a cross cut dado, though. Using a miter gauge doesn't prevent tear out like a sled will. Report
March 25, 20197 yr comment_183993 I only use the cross cut sled to cut a multiple of pieces. I just use a good miter gauge for the few dadoes I cut. It's is not something I do on a regular basis. Report
March 25, 20197 yr comment_183994 5 minutes ago, Gene Howe said: Quite true for a rabbeting cut. A ZCI would be nice for a cross cut dado, though. Using a miter gauge doesn't prevent tear out like a sled will. True. I have a zero clearance plate for my tablesaw. In the case of a tear-out I just use a backer with the miter gauge. I just don't see the need for all of the extra work to install into, and maintain inserts on a sled. Again, just my personal opinion. Report
March 25, 20197 yr Popular Post comment_183998 31 minutes ago, schnewj said: True. I have a zero clearance plate for my tablesaw. In the case of a tear-out I just use a backer with the miter gauge. I just don't see the need for all of the extra work to install into, and maintain inserts on a sled. Again, just my personal opinion. Yeah, but some of us are just fiddln' types. Report
March 25, 20197 yr Author comment_183999 Thank you for all the replies and suggestions. Lots of food for thought. Reading all the sled build articles.....different techniques for attaching the runners, different runner materials, different fence building techniques, different sled sizes, materials, etc. Report
March 25, 20197 yr Author comment_184000 2 minutes ago, Gene Howe said: Yeah, but some of us are just fiddln' types. And looking for an excuse to use our woodworking tools and make some sawdust. Report
March 25, 20197 yr Popular Post comment_184037 5 hours ago, JIMMIEM said: Thank you for all the replies and suggestions. Lots of food for thought. Reading all the sled build articles.....different techniques for attaching the runners, different runner materials, different fence building techniques, different sled sizes, materials, etc. You may have just hit the "jack-pot" for your wishes? Latest Woodsmith eTip Video Premium Plans are a little pricey at $12.95 IMO...with some creativity and watching the video, I think you could replicate & customize for your specific needs. Report
March 25, 20197 yr comment_184040 13 minutes ago, Grandpadave52 said: You may have just hit the "jack-pot" for your wishes? Latest Woodsmith eTip Video Premium Plans are a little pricey at $12.95 IMO...with some creativity and watching the video, I think you could replicate & customize for your specific needs. Thanks, I like it, That is the best solution I have seen. Herb Report
March 25, 20197 yr Popular Post comment_184047 1 hour ago, Dadio said: Thanks, I like it, That is the best solution I have seen. Herb Agreed...much better then an insert. All of the components are easy to replace as a sub-assembly if necessary, also. It provide immediate, infinite adjustibility. Report
March 25, 20197 yr Popular Post comment_184048 9 hours ago, schnewj said: I'm a little confused! Why would you need a zero clearance insert for a cross cut sled? Typically, when you cut the sled with the blade it only cuts a slot the width of the blade. If you are talking about the back of the sled and the "pass-through" getting chewed up, then just again, why? The material is being held and just gets cut...worried about chip out on the material...use a backer. What am I missing? the sawdust will wear away the edge of the plywood it happens faster than we would think Report
March 25, 20197 yr Popular Post comment_184052 2 hours ago, Grandpadave52 said: You may have just hit the "jack-pot" for your wishes? Latest Woodsmith eTip Video Premium Plans are a little pricey at $12.95 IMO...with some creativity and watching the video, I think you could replicate & customize for your specific needs. Ya hit the nail on the head with that, Dave. Thanks. Report
March 25, 20197 yr Author comment_184053 2 hours ago, Grandpadave52 said: You may have just hit the "jack-pot" for your wishes? Latest Woodsmith eTip Video Premium Plans are a little pricey at $12.95 IMO...with some creativity and watching the video, I think you could replicate & customize for your specific needs. Gee, I thought I hit it when I found plans in a 2013 ShopNotes Magazine issue for the 'Ultimate Crosscut Sled'.....lol. It used a hardboard insert and dual runners (to eliminate side-to-side movement). Times they are a changing! The 'Ultimate' plans are available to purchase for $15.95. Report
March 26, 20197 yr comment_184057 58 minutes ago, JIMMIEM said: Gee, I thought I hit it when I found plans in a 2013 ShopNotes Magazine issue for the 'Ultimate Crosscut Sled'.....lol. It used a hardboard insert and dual runners (to eliminate side-to-side movement). Times they are a changing! The 'Ultimate' plans are available to purchase for $15.95. Who needs plans ,all a guy needs is the picture, done deal. Herb Report
March 26, 20197 yr comment_184071 2 hours ago, Gene Howe said: Ya hit the nail on the head with that, Dave. Thanks. Do I get a raise? Report
